Evoscan saving data in wrong columns causing MapTracer error (csv attached)
I've been running EvoScan v2.9.0.100 with TephraMod v5.10 for 6 months without issue. I finally decided to upgrade to TephraMod v7 this week (only change) and since then have been having problems with EvoScan logging data into the wrong columns in the .csv log which causes an error when I try to review it in MapTracer.
I can go into the .csv and manually move the data to the correct columns so it works but I can't figure out why this has started.
The error I receive when trying to open the messed up .csv is "System.IndexOutOfRangeException"
I have attached the messed up .csv so you can see what it's doing.
Has anyone else ever encountered this issue before?
Thanks in advance for any help!
Sounds like your Mitsubishi MUTII EFI.xml file may have been messed up during the upgrade. This file contains the list of data items to log. Without it, Evoscan doesn't know what to write to the csv file. You should have an original copy in the ..\EvoScan v2.9\DataSettings\ folder.
Siege (Oct 24, 2016)
cyberevo23
Feb 27, 2018 09:11 AM
6spdlegend
Apr 30, 2015 11:48 AM
detroit pistins
Apr 9, 2014 08:03 PM
Bster13
11
Mar 28, 2008 07:57 PM
