Help! Rough Idle and no boost!
Hello! My name is Michael and I have a question for all you guys. Recently I had put a 7163 borg warner turbo kit on my evo 8 pushing 500 whp. I made a mistake with this by keeping stock internals. A few months after I had spun a bearing.
6 months later and an empty wallet, I got my car running again, with Manley Rods and JE pistons, stage 3 head, and a machined block and head. Turned the boost up to 33 lbs.
Car was running great, now im having a problem and I don't know what is causing it.
While my car is moving at idle (in neutral coasting), the RPMs bounce between 1 and 2 thousand. Then when I come to a complete stop, The RPMs hang right at 2k.
While im in high boost, past 5k RPMs, the engine sputters and does not give full power.
I have heard these problems could be a vacuum leak, boost leak, bad EGR solenoid or spark plugs. Please help!!
Graphic
Jun 16, 2012 11:45 PM
VOLFLO
Mar 26, 2007 06:13 AM
