Evoscan Wont log
Evoscan Wont log
So ive been trying to log with evoscan but no luck everytime i connect to it it says its connected but when you look at the live data its going ballistic whether the car is on or off. ive tried different drivers as well as different versions of evoscan. when i use ecuflash to pull the rom off it works flawlessly. any help would be appreciated
Thanks
Thanks
You didn't say so I'm going to have to assume that you have the 1.3U cable - right?
1.3U Cable
Check the OBD 2 BaudRate (usually 15625) setting in your ROM matches the setting at the top left of the screen in EvoScan. If not make them the same.
Turn off the Logging > Log Data to Screen option, and leave on Logging > Log Data to File.
Remove the check mark from the Offline Test Mode box
1.3U Cable
Ev0la (Jan 22, 2017)
So i turned off log to screen and it was still acting up so i took evoscan 2.9 instead of 2.8 and for some reason now everything works i can see everything now. thank you so much for your help
black_beauty
Aug 20, 2012 10:11 AM
HR2L
Nov 29, 2010 12:53 AM
