Building Your Own Turbo Kit. Noobs please click!
To be successful on your project, you must do lots of homework and especially do a lot of research! Building one on your own will take time, so be patient.
You can visit this site to learn more about turbochargers
http://auto.howstuffworks.com/turbo.htm/printable
I spent about an hour searching for you guys (those people who are lazy to search), went throught about 26 pages , well if I miss a link or an info, please post. I'll try to edit if I find more info.
Below are the links you will need to find out how to build your own kit and some good informations you will need later on (take your time to read those info).
http://sclc.net/sclc/forums/viewtopic.php?p=14697#14697
Rhyzin's guide to turbocharging.
https://www.evolutionm.net/forums/sh...d.php?t=106930
Rhyzin's guide to fuel system.
https://www.evolutionm.net/forums/sh...ighlight=turbo
Using 16G6 turbo with lists.
Guide to installing your own kit.
Setting up your turbo install.
Custom turbo information with lists.
"What turbo are you running?"
Vortech FMU.
Sparks plugs.
Priming your oil feed lines.
Pete's (maxum17ft) set up, very good info.
T3/T4 turbo info.
Oil type on turbo Lancer.
Tapping an oil return.
Good turbo informations, answer to turbo questions.
Other custom turbo project with lists.
Using T4 turbo with lists.
http://www.importperformanceparts.ne...man-mitsu.html
Cast iron turbo manifold: $339. Will fit Garret Turbo T25, T25BB, T28 and T28RS.
Water cooled turbo.
Water cooling your turbo.
Using T-25 turbo from 2G Eclipse.
Other turbo projects with lists.
Using T4 turbo.
http://www.homemadeturbo.com/forum/i...8725#msg288725
Another guide to building your own kit.
http://www.sdsefi.com/techdynojet.htm
Tuning on Dynojet
http://www.sdsefi.com/techegt.htm
Tuning Via EGT vs, Wide Band/ Narrow Band Meters
http://www.sdsefi.com/injectors.htm
Injectors informations.
http://www.sdsefi.com/techheader.htm
Fabricating custom manifold.
http://www.sdsefi.com/techmap.htm
Engine map examples.
http://www.sdsefi.com/techign.htm
Ignition Tuning Ideas for Turbos.
http://www.sdsefi.com/techocta.htm
Fuel Octane vs. HP
http://www.cheapturbolines.com
Complete oil line kit for $78, great stuff, look great (I had a problem on their shipping but it work out ) But you will need to order longer lines from them or just buy from your local auto store.
Okay, those are the links you might need to build one on your own. If you didn't the information you need, please search about it, there are tons of threads about building one your own so before you start another thread with same topic, PLEASE CLICK HERE.
Like I said, if I miss links or informations , please post. Well thanks for looking and goodluck
Vortech FMU.
Sparks plugs.
T3/T4 turbo info.
Water cooled turbo.
Using T4 turbo.
Tuning on Dynojet
Fuel Octane vs. HP
some extras:
https://www.evolutionm.net/forums/sh...ad.php?t=51231
Hobie's links to "How to read compressor maps"
http://www.vfaq.com/mods/Turbo-compressor-maps.html
Another compressor map reading link
http://not2fast.wryday.com/turbo/maps/
Turbo compressor maps (garrett, mitsu, kkk, IHI, etc)
CharlieGsanD
Nov 8, 2004 05:18 PM
