The Injen Technology SP1811 2015 Lancer 2.4L 4 cyl. (5 Speed Transmission MODELS ONL
Old Feb 20, 2017, 03:55 PM
injentechnology's Avatar
Injen's SP Series Cold Air Intake is custom-designed for a precise fit
Specifically built for radical top-end power gains in high-performance autos
Specially engineered to ride right behind your front bumper, where it gathers fresher, denser, colder air
Your SP Series Cold Air Intake unleashes your engine's power potential by force-feeding rich oxygen into your cylinders, which improves combustion efficiency
Wrought from premium slabs of aerospace-grade T-6061 billet aluminum—famous for its high strength, light weight and excellent corrosion resistance
For unrestricted air flow, the SP Series Cold Air Intake is CNC mandrel bent
Every SP Series Cold Air Intake includes a reusable, high-performance cotton-gauze air filter with a built-in velocity stack
Dyno-proven for maximum, reliable horsepower gains
Your SP Series Cold Air Intake comes with stainless steel clamps, silicone hoses and detailed instructions for a simple at-home installation
Injen's groundbreaking rubber "vibra-mount" system cushions against engine torque
Choose your finish: polished or wrinkle black (pictured)
This product is designed and manufactured for the 5 speed model only.
This tuned cold air intake delivers +9 Horsepower and +8 lbs. of Torque
Where the SP Series Short Ram differs from conventional short ram systems is the inclusion of Injen's patented MR (Mega Ram) Technology. MR Technology allows this system to attain increased intake airflow and performance while maintaining a safe air/fuel ratio. Injen steps down the diameter of the intake tube where the Mass Air Flow (MAF) sensor mounts, enabling the sensor to detect airflow within established parameters. The engine control computer can then maintain the proper air/fuel ratio and optimize horsepower and torque. Simply put, MR Technology tunes the intake system to avoid the necessity of recalibrating the MAF sensor, and prevents your engine from running too lean or too rich. With MR Technology, Injen created "The World's First Tuned Intake System", delivering optimum performance with a factory safe air/fuel ratio.
The SP Short Ram system installs in place of your factory airbox and air intake tube. It's carefully engineered, with CNC machined brackets and adapters, to ensure an exact fit. Installation is fast and simple and can be completed under the hood. There's no need to get underneath the car or do any significant component relocating. Everything necessary for installation is supplied, including comprehensive instructions. The SP Series Short Ram Air Intake System is backed by a Limited Lifetime Warranty.
For more on this and other Injen Cold Air Intake Technology for your Lancer please visit us at www.injen.com
injentechnology
Vendor Classifieds
Jan 16, 2017 09:51 AM
injentechnology
Evo X Dyno Results
Sep 21, 2016 07:23 AM
injentechnology
Sep 9, 2016 11:11 AM
Bysek
10
Jan 6, 2014 04:18 PM
Quick Reply: The Injen Technology SP1811 2015 Lancer 2.4L 4 cyl. (5 Speed Transmission MODELS ONL
