stereo wiring help
Old Feb 27, 2006, 09:05 PM
t-dotlancer's Avatar
stereo wiring help
okay, any help would be appreciated..
my after market deck has the following wires on the back...
-power constant
-power ignition
-ground
-illumination
the lancer wiring diagram in the shop manual descibes the following...
- power constant is a (red blue wire)
- power ignition is a (blue yellow wire)
- front ecu taillihgt relay (green white wire)
- rheostat (black yellow wire)
most of this is obvious but what do i attch the ground, and the illuminatio to??? any suggestions?
Old Feb 27, 2006, 09:24 PM
i have done an exstenive search and i am now reading that i do not have to use the ground wire because the deck grounds itself by being bolted to the car.
so what would some one connect to the - front ecu taillihgt relay (green white wire) and the rheostat (black yellow wire)
Old Feb 27, 2006, 09:28 PM
BoostWhore's Avatar
IF i was u I would ground the wire back behind the dash and use the power and ign wire thats all u dont need illumination.
Old Feb 27, 2006, 10:10 PM
dss64bit's Avatar
if your harness doesnt have the same wires as what comes from back of deck you dont use it so just electrical tape the ends of them and tie them together out of the way. to hook up your deck to existing harness u just use the power(constant),acessorie(ignition), speaker front/back/left/right
if your first time just take your time and make the wiring neet and make sure the wires are connected together tightly
Old Feb 27, 2006, 11:18 PM
RumbleCam's Avatar
or for 10 bucks you can get a wiring harness that clips in to your cars wiring harness and you dont have to butcher your cars stock wiring.
and it has instructions
Old Feb 27, 2006, 11:21 PM
micropm's Avatar
+1
Unless your good a wiring just buy a harness.
Old Feb 27, 2006, 11:23 PM
evo4g63awd's Avatar
i would have gotten a wiring harness, makes for an easier installation that way you can put your factory radio back in if you sell the car
mitsu's dont have grounds, so ground it to a bolt.
illumination- no one needs that crap anyways, same with the dimmer
Old Feb 27, 2006, 11:27 PM
RumbleCam's Avatar
im good at wiring but i just bought a harness caz i didnt want to cut up my new cars wires.
just made sense.
Old Feb 27, 2006, 11:43 PM
dss64bit's Avatar
i forgot to mention that harness adapter i figured he already had one
Old Jul 24, 2007, 07:51 AM
edwin's Avatar
http://www.installdr.com/Harnesses/M...shi-Wiring.pdf
tboboy
Aug 7, 2010 03:39 PM
stanley2
Feb 17, 2010 09:34 AM
TREVORSEVOVIII
Jan 6, 2008 10:07 AM
Deepseadiver
Oct 22, 2006 07:40 AM
dreamevo
Sep 20, 2006 06:50 AM
Quick Reply: stereo wiring help
