Amp and Sub Installation - Step by Step
#64
the wiring is so clean and i might do the same too. i have one more concern, how and where did you connect the remote wire? from the amp to where and how did you do it? pictures will help a lot. thanks!
#66
Suditz it goes to the remote wire on the radio harness.. I will be installing my amp kit tomorrow thank god i found this cause i was avoiding installing it based on finding where to run the 12v wire
#68
right side side of engine on fire wall there is a black rubber grommetu can push in and run any size wire through there I ran a 4 gauge wire through there to the amp under my pass. seat
#69
actually i found that theres a whole cut out already in the insulatuion under the dash.. located on the laft side around where your clutch pedel should be.. if you pull it out there will be a hole already made threw your fire wall sized about for a 2 gauge wire.. but you shouldnt need that big of a gauge wire no bigger then 4 gauge for just some regular tubs
nerdbotSKRA
04-06 Lancer Ralliart How To Requests / Questions / Tips
13
Jan 28, 2012 12:41 PM
gunvalk
Lancer How Tos / Installations
Feb 24, 2010 09:00 PM
93civEJ1
Apr 12, 2004 11:54 PM
