Pros! can you help please?!
Guys, having a problem with my system install. I am not able to bridge my amp. The left and right channel work independently but together they do not properly function. i plugged my i pod into the amp with rca males that split from the head phone jack female. amp and sub works fine and is working bridged.. Im assuming that there is a problem with the line out wires that i spliced to the speaker wires. i have used the colors that I found on this forum. i have tried multiple times to find out if these are correct but have failed. i took off the door panels but the yellow and green coming off of the speaker is switched through a harness in the door column. Guys can you please help with this. System sounds like **** and need to get it figured out. 09 lancer GTS no sun and sound or navi.
Thanks...
Thanks...
Thanks...
Thanks...
I don't think you can hook up an amp/sub to a non-S&S lancer. The S&S has a specific sub channel you tie into with your LOC. I am fairly positive if you want to do what you're trying to do in a non S&S lancer, you need an aftermarket Headunit. Good news is for somewhere around 200 to 250 bucks can get you everything you need (HU, Dash Kit, Harness)
No, I think you're confused. I was explaining your last question, that's how he can use an ipod directly to it and hear the music.
Thanks, for the advice so far. For the guys that had it installed. I have tapped into the rear speaker wires by the kick plates on both the drivers and passengers doors. Do you know what colors you tapped into so that i can cross reference it with the ones that I have tried?
oh i see, but i meant hook it up and actually hear words and music, and not just the lows from just subs, unless the amp was on HPF instead of LPF.
there are a few threads I think on what wires to use, maybe even a sticky or two. look in the how-to section. I forget the colors off the top of my head, but i think its something like purple and yellow....
Ah, yeah, I'm not to knowledgable about splicing into our stuff because I'd rather do it the right way and upgrade everything. The stock stuff, even with S&S package is just plain crap. The Sub box isn't even air tight and rattles like a ****.
bigd31388
33
Aug 20, 2012 07:59 AM
bigd31388
Lancer How Tos / Installations
Dec 2, 2007 12:22 PM
