Speaker problems
Speaker problems
My 2 rear speakers dont work at all. NO sound whatsoever. Can they be blown are is the problem a fuse?
What wattage of speaker can replace these without changing the stereo. Sorry if i used incorrect terms, I dont know much about speakers.
first check if on accident you didn't change the fade just to the front and for watts if your going after market doesn't matter the only thin is that they wont sound good at real high volume the stock speakers are 15 watts so any thing you get is already more hopefully it was just the fade on your stereo
Pretty sure they are not blown cause you usually can her a blown speaker they just sound really bad, is there anything that led up to the no sound? Or did it come like that when you bought the car? And like ozrally06 said maybe its just the fade
plus there was this raspy, rattling sound that i used to hear, but I thought it was the exhaust tip, but now i dont hear it. Can blown speakers just give up and make no sound?
i would pop the door panel off and see if the harness is still pluged into the speakers. if it is then inspect the speaker itself for rips and whatnot. if still nothing then give em a whiff and see if they smell like burnt plastic
