Which Speaker??
not components... since you dont sit in the back.. either 2 or 3ways that you like.. try to find a set that handles bass well too.. i personally dont have any specific brand.. maybe infinity or alpine
You should always try to have the same size and type of speakers in the front as you do in the back of the vehicle. It is the best possible configuration for optimal sound imaging. If you mix up sizes and types your ears will have a tendency to be bias to specific speakers and you will not get the full effect of the sound.
But, whatever floats your boat. Rock On
Originally posted by TURBOit
my audio shop said the new kenwood eXcelon's are amazing
i went with two apline type-r component systems. four 6.5" midrange and four 2" tweeters total, including my two 10" type-r subs, 1 farad cap and 1200 watt amp.
Sounds amazing. Not only bumps but is crystal clear sounding. Of course I hooked this to an apline cd deck
Originally posted by MP5
BS
BS
I would disconnect the rear speakers and just run the fronts, maybe make some kick panels to enclose the speakers so they better project the sound to your ears. But..
do what yah want, yah will anyways..
Whatever man, imaging is where it is all about. You could fill your car with a crap load of speakers and yes it would be loud, but it would sound like crap. Acoustic echo is what I am refering to, the position and the relationship between you and the sound and whats in between is what gives the sound its definition. Its the difference between good sounding and excellent sounding. Its all in what your going for and what you wanna spend. I'm just givin my $.02
just let it go.. back to the original question.
If your going to go with rear speakers I would put the same focal components in the rear that you had in the front. If your into multimedia you could go for surround sound. Take a .1mH air core inductor and run it in-line with the positive power supply for the tweeter which will cause a low pass crossover at like 9k resulting in a surround sound affect for your car.
