Confirmed: Evo ROM Can Be Flashed to Lancer ECU
#229
RoadSpike,
Do you have any issues with startups on E85?
Its annoying to have to push the gas pedal to help the car start when the engine is warm.
When the engine is cold, it starts right up without pushing the gas.
Im guessing I have to lower the "Fuel Primer First Pulse" and "Post Primer Crank Enrichment" tables in the appropriate engine temperature, right?
What does the "Post Primer Decay Multiplier" map do?
#230
RoadSpike,
I would definitely be lowering the first primer pulse in the warm areas if you are having to open the throttle to start it.
The injector decay table doesn't appear to be labeled right when i was looking at it so i just leave it stock and mess with the tables i know works like post primer and initial pulse.
The primer enrichment decay just keeps the gas coming in for a number of seconds basically just enough to get it warm enough to idle right.
#235
Ok so i'm not really getting anywhere without the ability to just directly test the data. So this is what i'm going to do. I found the maps all 32 of them and 2 that are unknown are broken into 4 states.
I laid out the maps in order of their placement in the rom.
I know that there are basically two factors that decide what map the car is running in. I will hazard a guess one of the factors is during braking. The other is unknown to me at this time. I know it has something to do with the testing of certain factors like if its in drive or not but i can't really tell. It may be something as simple as a gear lever selection.
Maps 1 & 3 are related to eachother
Maps 2 & 4 are related to eachother
I labled the maps inside each category according to their placement in a variable so map 1 is the same as a map 1 of another category. I'm fairly sure that each category has to do with shaft speed of the transmission rather than rpm of the engine since they climb for each gear. There seem to be obvious downshifting maps in each one too.
One of the people on ecuflash said that maps with the first one so I think we should try messing with shift maps 1 and see their effects. It should be pretty obvious if you set the whole map to 1 value to see when the shift point occurs.
PHP Code:
<table name="Shift Map 1" category="Shift Maps 1" address="419f6" type="2D" level="1" scaling="uint8">
<table name="load" address="41174" type="Y Axis" elements="32" scaling="ThrottleVoltage16"/>
</table>
<table name="Shift Map 2" category="Shift Maps 1" address="41a42" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 3" category="Shift Maps 1" address="41a8e" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 4" category="Shift Maps 1" address="41ada" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 5" category="Shift Maps 1" address="41c0a" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 6" category="Shift Maps 1" address="41bbe" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 7" category="Shift Maps 1" address="41b72" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 8" category="Shift Maps 1" address="41b26" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 5 Condition 2" category="Shift Maps 1" address="48130" type="1D" scaling="uint8"/>
<table name="Shift Map 6 Condition 2" category="Shift Maps 1" address="48134" type="1D" scaling="uint8"/>
<table name="Shift Map 7 Condition 2" category="Shift Maps 1" address="48138" type="1D" scaling="uint8"/>
<table name="Shift Map 8 Condition 2" category="Shift Maps 1" address="4813c" type="1D" scaling="uint8"/>
<table name="Shift Map 1" category="Shift Maps 2" address="41a1c" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 2" category="Shift Maps 2" address="41a68" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 3" category="Shift Maps 2" address="41ab4" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 4" category="Shift Maps 2" address="41b00" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 5" category="Shift Maps 2" address="41c30" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 6" category="Shift Maps 2" address="41be4" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 7" category="Shift Maps 2" address="41b98" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 8" category="Shift Maps 2" address="41b4c" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 1" category="Shift Maps 3" address="428a0" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 2" category="Shift Maps 3" address="428ec" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 3" category="Shift Maps 3" address="42938" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 4" category="Shift Maps 3" address="42984" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 5" category="Shift Maps 3" address="42ab4" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 6" category="Shift Maps 3" address="42a68" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 7" category="Shift Maps 3" address="42a1c" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 8" category="Shift Maps 3" address="429d0" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 1" category="Shift Maps 4" address="428c6" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 2" category="Shift Maps 4" address="42912" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 3" category="Shift Maps 4" address="4295e" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 4" category="Shift Maps 4" address="429aa" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 5" category="Shift Maps 4" address="42ada" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 6" category="Shift Maps 4" address="42a8e" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 7" category="Shift Maps 4" address="42a42" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 8" category="Shift Maps 4" address="429f6" type="2D" level="1" scaling="uint8">
</table>
#237
We are working on getting the auto transmission evo 7 rom working for the 2002-2004 lancers.
I'm pretty sure we can make the 05-06 ones work too but they need special xml's to run ecuflash properly. 05-06 seem to use the mitsukernelocp method instead of mitsukernel.
Did confirm the 2002-2004 roms will work on a 2005-2006 but again the special xml is required to make it work.
#239
so a lil update i tried the gta rom again and put my lancer shift pressures and times and other things from my lancer rom and theres still no power to the tranny, when i push on the pedal the engine has to rev to 2-3k just to start to get the car to move foward and i still get massive amount of knock when i go anywhere near boost idk if its cause the knock filters are diff or somthing else but when i get a chance RS ill try to mess with the maps
#240
Ok buddy.
Thats interesting its letting the torque converter stall like that wondering why the lockup isn't going as intended.
