Lancer 08+ ECU Pinout in relation to wideband install.
Hay folks, I am doing the preliminary to install a LC-1 in the front O2 sensor position on my 09 Lancer GTS 2.4.
I found a EvoX ECU pinout with what I assume to be a common pinout scheme across all the similar Lancers. It lists the following pins in relation to the front O2 sensor.
34 Heated O2 sensor (front) heater
38 Heated O2 sensor (front)
39 Heated O2 sensor (front) offset voltage
Does anybody know which pin on the ECU I need to tap to feed the wideband 0-1v narrow band emulation signal into the ECU? I expect it's either 38 or 39, but I am unsure as to which.
Edit: format got buchered
FLASH1970
Lancer Engine Management / Tuning Forums
Jun 11, 2016 08:38 PM
