Ecuflash 05-07 big map rev limiter
Old Jun 1, 2012, 06:31 AM
marcouxa1's Avatar
Hey guys i finaly got ecuflash to work and flashed the 05-07 big map rom.....now im wondering how the rev limiter works...there's rev limiter.stationnary rev limit and rev limiter 2. i was wondering if you can change the rev limiter with no load applied like in P or N to change the cutoff rpm?
Old Jun 1, 2012, 12:33 PM
RoadSpike's Avatar
both need to be changed
Old Jun 2, 2012, 08:11 PM
marcouxa1's Avatar
Will that change it only when im in P or N or when im driving too? because it seemed to change the rev limiter in any circumstances not only in P and N!!!
Old Jun 3, 2012, 11:27 PM
RoadSpike's Avatar
They effect the rev limit in ALL circumstances but BOTH must be changed.
The first rev limit is a fuel cut a hard stop so the motor physically will not reach the rpm limit. The second is a timing reduction or soft cut so the car will lose power and be unable to climb further thus both must be changed.
Old Jun 4, 2012, 02:51 PM
marcouxa1's Avatar
Aight thanks! is there a way in your Big map to change the fuel cutoff only in N or P to start spooling the turbo when you're at the track?
Old Jun 4, 2012, 04:43 PM
RoadSpike's Avatar
No unfortunately that kind of tuning wasn't thought about for auto's. A safer bet if you plan on doing serious drag racing would be a higher stall torque converter and a transbrake so it wouldn't need the settings.
Old Jun 5, 2012, 01:02 PM
marcouxa1's Avatar
So there is no way to get a launch control with the big map?
Old Jun 5, 2012, 01:07 PM
RoadSpike's Avatar
no its not possible.
blitzkreig
Jun 20, 2016 10:35 AM
89turbosupra
Oct 9, 2015 09:51 AM
megali_6969
Apr 6, 2012 05:47 AM
Quick Reply: Ecuflash 05-07 big map rev limiter
