A little tuning help please?
#47
Yeah, the Eclipse values don't work for me with the 501. It runs well, but idle is a tad rough and I go over 100 load. I'll scale it when I get the wideband.
#48
Smooth out your fuel map. Especially the part were it goes from 14's down to 12's. It should gradually go down. But this is how mitsu has it setup from the factory. Those 11's are definitely way too rich. I would start by smoothing out your fuel map. That should help out a lot. Use your "afr map" as reference for now until you get a wideband. Your LTFT were pretty good so the AFR map should be close enough.
#49
#51
Not yet Jaker. I will flash it on and do a couple WOT runs later. I'm working on smoothing out my timing map too. I wish the maps would have been set up better from the get go, but I guess this is helping me learn more.
#56
I agree, I think I should wait to mess with the fuel anymore until I have my wideband. I will be ordering it next Friday. In the meantime, I have another question. would it be beneficial to me to change the range on my timing and fuel maps? Since you are never really at 0 RPM couldn't I change the lowest field to 500 and give myself a little more accuracy?
#59
To do that I just change the values on the axes right? So, I could make it 0,10,40,50,60 and break up the rest to smaller values? Should I change the ignition and fuel maps to match?
