Forged 4B11 internals
I am wondering if anyone knows of any company that has or is considering to manufacture forget and light internals for the 4B11 NA? Im interested in forget high compression pistons, forged rods, lightweight crankshaft etc.
We really need these to get higher NA numbers
best to contact a company and get custom ones made. if you can provide info, they can usually make them. for rods and pistons. the crank in the NA lancer is forged steel, so I dont see that as giving us much trouble. good luck, and i know evo X pistons will fit with custom sized rods (same diameter)
But how heavy are the evo x pistons as compared to the lancer ones? The reason im asking is I also need lighter engine components so it can safely rev higher. Also the evo x pistons will lower my compression which is something u dont want on a NA motor... guess its custom time again
INJEN///
Lancer Aftermarket Forced Induction Tech
Sep 24, 2010 12:23 AM
4b11, compressionn, crankshaft, engine, evo, forged, gts, high, hyundai, lancer, lower, mitsubishi, na, piston, pistons
