Catalytic Converter for 2003 Lancer OZ
Old Dec 25, 2010, 06:12 PM
Beluga's Avatar
Check engine came on and when my mechanic connected it to computer, it showed oxygen sensor before cat and we changed that. Week later it came back on, so now I am thinking it's probably Catalytic Converter. Any suggestions which one should I get? Also is it worth it to change the whole exhaust with some high flow cat, car is 100% stock.
I have full exhaust with cat from 2004 Subaru STI, this cannot fit on lancer, right?
Old Dec 25, 2010, 06:25 PM
escodotcarter's Avatar
there was a TSB on the Cat from mitsubishi.........did you ever have it serviced for the recall?
EDIT: duyyyy...didnt even read that it was a STI exhaust lol wtf
Old Dec 25, 2010, 08:00 PM
JRR
JRR's Avatar
thats like putting ford parts on a chevy. no it wont fit. the exhaust is 180 degrees the opposite way.
Old Dec 26, 2010, 07:54 AM
slatermvp's Avatar
there was a recall on the first cat converter...take it to the dealership and make sure they take care of the recall otherwise you are going to be wasting your money and time.
Old Dec 27, 2010, 10:36 PM
Beluga's Avatar
Are you sure it's the recall for 2003 lancer as I couldn't find info anywhere on the recall for the cat on this year
Old Dec 28, 2010, 12:29 PM
Shingen's Avatar
What they say is true. Just call up the dealer with your VIN and they can verify if the work has been done to address the situation.
Had a similar issue with my girlfriend's lancer. Except her's was a 2002 and they wouldn't honor the warranty on the cat.
Old Dec 28, 2010, 12:30 PM
BlueKnight32's Avatar
if it is a recall just tell them that its a factory construction flaw and they should fix it also show them your recent purchases for any oxygen sensors or work done to it.
Old Dec 28, 2010, 07:07 PM
slatermvp's Avatar
I think they won't do the recall after 100k so you might be out of luck with that.
Old Dec 28, 2010, 10:00 PM
03lances's Avatar
Yup I can vouch. Long before going to turbo my 03 had the same issue. I took it up to the dealership and got a brand new cat and install free under warranty
This is true IF he is over 100k but I dont see anywhere in this thread stating his mileage so idk.
Old Dec 29, 2010, 05:26 AM
slatermvp's Avatar
I didn't take mine I just used the CEL eliminator on my second o2 sensor and it got rid of it.
Old Dec 29, 2010, 10:03 AM
HavocNinja37's Avatar
I had this same problem, switched out the o2 sensor fixed my problem temporarily and then the cat went out. Turns out though that if you have over 100k on the car you are not eligible for the recall anymore. =/
Old Jan 4, 2011, 10:30 AM
Beluga's Avatar
I just called the dealership to check if there is any recall on my 2003 lancer oz and they said that there isn't any open recall on this vehicle, and I gave them the vin. So I guess I just have to replace the cat. Any brands that you recommend?
Old Jan 4, 2011, 01:10 PM
fe2o3's Avatar
I don't think it's referred to as a "recall" per se. I think it's some kind of warranty extension on the service life of the part through some kind of technical bulletin from 80,000 miles standard emission to 100,000 miles. I've heard of people having trouble getting the service advistards to do the searching and calling to verify it. I think they have to input the service order for it to show up that it will be covered under warranty. I'd push them to do some calling around if they have to because people have had this covered or try another dealer if you have some around.
I fell outside mileage so had to replace. From rockauto.com, I used:
Front: Eastern cat #40674 @$350, came with all new bolts and gaskets
Rear cat: Bosal #0991817 @$148, no bolts and holes aren't threaded to reuse yours, did have gaskets
Not endorsing these one way or another as great parts, just saying they work and bolt right in for my 02 ES (except for having to buy a few bolts for the rear one)
Old Jan 4, 2011, 03:14 PM
JRR
JRR's Avatar
wow... you overpaid! where i work i can get everything for under $250 shipped....
Old Jan 4, 2011, 03:32 PM
fe2o3's Avatar
Care to post up the info/source? I'm probably going to need to replace them on my brother's Galant soon. I'll order it from where you're getting it.
Quick Reply: Catalytic Converter for 2003 Lancer OZ
