Turbocharging a lancer limited
I'm about to get the lancer limited the 1.8L engine version.
Can i turbocharge it with a ralliart kit?or like an aftermarket kit?
(Assuming i'm using proper cooling and not overloading the engine)
Any customizations (Cutting/Welding/Drilling) should be done ?
You can turbo it, however you're only going to be able to run 1-5lbs of boost, and it might kill your transmission early on if you DD it. Don't buy from RRM if you're looking at those, heard some nightmare stories about them in terms of their turbo kit. There shouldn't be much customization to be done, you're going to have to relocate the battery to the trunk though.
James Catherson
Nov 7, 2017 10:29 AM
AWD_Nut
Lancer Aftermarket Forced Induction Tech
Sep 18, 2002 12:02 PM
