OZ spring removal
OZ spring removal
i already know the steps on how to remove the springs and have tried searching for a long time. i try to remove the nut that keeps the sring under the top "mounts" and the rod coming from the strut rotates with the nut and i did use wd-40. i was wondering if there were special tools to keep it from spinning both so i can remove that nut.
i haven't used an impact gun yet. the top mount plate rotates with the nut but maybe the impact gun will work. the rod in the middle seems like it has to flat spots for possibly a crescent wrench to grab.
Hell, for that...I just went into Sears (of all places) and had them impact those suckers off real quick. But of course, it does help knowing someone that works there. Good luck.
Well, Sears had a special spring/strut press to clamp together and put down-force on the spring to help with the impact gun taking that bolt off. Though...I really believe all of that wasn't necessary. Anyone else have to use such a press???
that would be a spring compressor, I used one, it's not entirely neccessary tho.
sjl6102 -- if you have the impact gun, you shouldn't need to hold the rod still, as the force of the impact gun should loosen that bolt. Just use something to hold the top plate, like a wrench on one of the studs and against another.
Tip3r
Sep 17, 2012 10:32 PM
undercoverpope
20
Jul 20, 2011 10:54 AM
4g94T
Aug 8, 2005 10:17 AM
MitsuJoe
Aug 1, 2004 01:59 PM
