A/C Recharge
A/C Recharge
Does anyone know how to do a a/c recharge on a 03 Lancer OZ? Mine isnt blowing as cold, so i was going to get one of those Casterol a/c recharge kits to recharge it, but I dont know what to do. So im hopeing you guys might know. Thanks in advance.
It's easy. Get the can that comes with the gauge and has the stop leak and oil built in. Odds are you have a very small leak some where in the system. The important thing is to make sure you connect the hose to the correct fitting under the hood. Follow the instructions and you should be fine. It is usually the fitting with the blue cap on it. In short start the car put the AC on high, shake the can up, connect it to the fitting under the hood. Check the pressure gauge on the can (most likey it will be low). Then pull the trigger till you at about the top of the green zone in the gauge and that is it.
where is a good place to get the recharge kit. im looking at schucks website and found the recharge kit, but it doesnt have any with stop leak only one with oil charge. would that still be alright? or do i really need to find one with stop leark?
if you have some one you know or in the family that working on HVAC/plumbing/gas piping, they have the right refrigerant for it and odds are they probably even have the gauges to do it as well. (my dad does this) it takes them about 5 minutes to adjust the right pressure and weights of the refrigerant.
I would think the all in one would be best because if you do have a leak you would want to use the one with the stopleak or you'll be back in the same boat again. I would go to either Autozone, Advanced Autoparts, or Pep Boys. You might even find it at a Walmart.
Ok lets see if i get all the steps right. Start the car, put A/C on high, shake the can. Connect it to the Cap with a H on it, Open the cap with a L on it. check the gauge then press down til the arrow reaches the green area, disconnect the hose and close both the H and L caps and it should be done.
Only connect to the side with the L on it. If you connect the can to H side it could blow up from the pressure going through it. I think it might even be a different fitting so you can not connect to the high side by accident.
