Can be installed the headlamps of the Evo X mr on the lancer GTS?
There was another person on the forums here who tried it. He said he got them mounted on the car but the wiring is completely different and is incompatible with the GTS.
I can't remember where I saw his thread but if I stumble across it I'll post a link.
their is an in-depth explanation of this here...
http://www.mitsubishi-forums.com/t41...tors333333.htm
i think it still possible, just now you noe you obviosuly need a d2s blub which was that guys stupid mistake not know that, and you need at least a whole saturday to be able to do this. thats basicly it. i am goign to try goign to a junk yard to pick me up a set of projector headlamps
Grrrr!
I went to the dearler and no body knows how to or if fit, so i called mitsubishi customers service on hold like 30 min and the same.
I went to another dealer and they say one time they try to install and the computer burned.... Amazing story.
I chack by my self and is not just plug and play the evo X gsr and the Ralliart with the basic headlamps have the same harness at the end on the connector but with just 9 pins and the projector from factory are 11 pins, another difference is the DRL on the basic one is on the low beam 9006 and on the projector the side beam close to the projector is the DRL 1156 bulb and the projector is like bi-xenon have a solenoid to change from low to high.
