Install Xenon Headlights [DIY]
This is probably one of the easiest things ever. Just be sure NEVER to touch the bulb or it will ruin it. Ill make this easy for all of us:
1. Pop Hood
2. Look behind the headlight to find a circluar thing about a couple inches in diameter.
3. Push and turn to the left the little 'turny' thing.
4. Pull out the old bulb carefully, try not to damage the bulb at all.
5. Just pull the old part out but dont touch the bulb because its hot and I burnt myself.
6. Put the new ones back in just like the way you removed the old one.
7. Push it back in and turn and thats all.
- I would start with the left side because there is more room and its easier to figure things out. You dont have to unscrew anything except the plastic part with your hands.
Discuss this install here.
1. Pop Hood
Evoryder
90
Jun 22, 2017 03:26 AM
diy, headlight, headlights, hot, ii, instal, instalation, install, installation, installed, laguna, light, lights, replace, xenon
