Lancer How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in in the Request sub-forum.
Changing reflectors
Old May 21, 2003, 11:54 PM
Moderator
Bomb Squad Unit #02
urbanknight's Avatar
For those who are going to replace their yellow reflectors with the clear or carbon fiber (or other) ones, here's how to do it. You don't have to take the bumper off. Here's how I did it:
- from underneath, remove the splash guards in front of the front fenders (held on by plastic plugs)
- unbolt the washer fluid reservoir from the right side (it will need to be moved out of the way to unscrew this side reflector). This may require removing some wheel well plugs to get to the bolts.
*I think this uses a 10mm socket wrench
- using phillips screwdriver, remove the reflector plates from the inside, then remove reflector
- install replacement reflector (not sure about yours, but mine used the stock screws)
- bolt the washer fluid reservoir back into place
- replace the splash guards
DONE!
Discuss this how to here.
urbanknight is offline
Old Dec 5, 2006, 07:58 AM
CadiLuva's Avatar
for the driver side just remove 4 clips from the splash guard and you will get a open space in the bumper where the reflectors' screws are..
CadiLuva is offline
Old Dec 5, 2006, 08:00 AM
CadiLuva's Avatar
heres the passenger side.. it was actually kinda tough getting to the screws.. even after you unbolt the reservoir.. there are connections that hold it together.. just drop the reservoir as much as possible and get in there over the top of it..
CadiLuva is offline
IncredibleChulk
Oct 31, 2007 09:49 AM
mscc04
Jun 26, 2006 11:25 AM
mxpx5678
Oct 23, 2003 09:03 PM
evoloz02
May 15, 2003 09:11 PM
Quick Reply: Changing reflectors
