2008 Lancer bulb list
#107
too cheap
So I found this online, too cheap to be true and not very familiar with the voltage or anything.. you think they'll work?? any thoughts?? I have a 2010 GTS not sure if they'll fit right
http://www.ebay.com/itm/281269313231...witem=&vxp=mtr
Combo 9006 9005 100/100W White 12V Halogen Headlight Lamp Bulb #w4 Hi/Lo BeamCombo 9006 9005 100/100W White 12V Halogen Headlight Lamp Bulb #w4 Hi/Lo Beam
#108
Interior and trunk lights
Has anyone considered sticking the side turn signal assembly (the signal closest to the doors) in the oven and baking it like you would with the headlight assembly? Only thing is that you would be baking it with a bulb inside but I don't think that would make a difference.
Also, has anyone replaced the dome and trunk bulbs with LEDs or any other differently colored bulb? If so, what are the specifications (socket type, etc) besides wattage, which is listed already.
Thanks in advance.
Thanks in advance.
I replaced my map light and trunk light with blue Led's. They are just your typical wedge bulb from normal inerior. Amazon has a bunch of different colored sets as long as you type in year and model and the ones you get should be right.
jimbo74
Oct 4, 2016 06:19 PM
