How To: Amp and Sub install walkthrough
I apologize to all of you in advance for the lack of pictures, I tend to be able to do a writeup effectively so I'll try to make up for it.
So the idea is that because there are no aftermarket solutions (that I know of) for those of us that did not get the sound system upgrade, if you want to install a sub and an amp you have to work with what you have.
This includes stock head unit, stock speakers, and no options for an RCA line output
The first item of business is getting a supply of a full 12v to the trunk. Now I have to say that I feel like I really found a great way to do this:
You obviously need to come off the battery and back to the trunk. (note: I used the Following "NS-Kit" install kit from diesel audio which came with everything i needed except one item for my capacitor)
The way I did it is like this:
The red flip cover on the positive terminal of the battery is in the way for a cable which is one problem. The second problem is that there is no way to use the terminal splitter that comes in the kit because of the harness that uses to connect the power. SOOoo in order to get a power cable connected to the positive terminal, take off the nut that tightens the terminal and then with a prepared power cable (cut and stripped with a round terminal connector crimped on) slide it onto the bolt that tightens the positive terminal and replaced the nut.
Now, face the cable away from the terminal. (towards you, if you stand in front of the car) Next, that red flip cover will now not be able to close, so to fix that carefully cut a slot out of the red plastic so that the cover will easily return to its default position around the new cable.
Next you need to install your 30A fuse somewhere close to the battery. So run your cable to the right, under the leg of the air intake thats right next to the battery, and straight back to the power steering fill up cap. Now leave some slack and twist your cable around that cap and the cable should pass right over the ECU.
The best place to secure the 30A fuse is on the plain aluminum brace that supports the top of the ECU. It's one bolt that is really torqued down but when you get it off you can tighten down the fuse assembly as you replace the bolt. You'll need to trim and strip the cable so that it stops at that fuse.
The next part is getting your power cable into the cab so that you can run it back to the trunk. One way to do this is to tie the new end of the power cable that you just cut, to power steering cap (this is temporary, and make sure to leave enough slack to wire it to the fuse) and then run it down and straight back from there. You should be able to spot some metal lines that run in a group of 4 (break lines?) and down to under-carriage level.
From below the car and behind the front left wheel, those lines will angle to parallel with the ground, at which point there is an aluminum debris shield. Pull the cable taught and zip tie it to the outwards most line at the point that they angle back.
Now this is the interesting part. Take the cable and pull it out from under the car at 90degrees to a point directly behind the front left tire. There is a plastic guard that is at the edge of the wheel well. It's held in place by four push button plastic fasteners. Pull the center out of the four fasteners and pull back that plastic guard so you can see the frame.
You should also be looking at a round rubber seal that plugs a 1.5" hole in the frame. The cable is going to be pulled through that hole and into the cab so pull the seal out and then you need to locate the hole on the other side that's inside the car
Open the drivers door and locate the two kick panels. The first panel you want to remove is the one that also surrounds the levers for the trunk and gas cap. Just get underneath them and pull straight up. You dont need to worry about breaking anything, it all just snaps down anyway. The next panel you need to pull off is the one that surrounds the lever for the hood. Again you can just pull everything off, but at the back of this panel next to the clutch pedal there is a plastic nut that could be unthreaded but it will still pull right off without breaking. Set these aside.
Now, under the second panel you just removed you should see the frame. Locate another one of those rubber seals, this one will be a bit bigger at about 2". Pull it out. This next part is tricky. You need to pull apart a wire coat hanger and snake it through FROM THE INSIDE to the hole behind the wheel. TRUST ME! It will seem like they don't connect because it is EXTREMELY DIFFICULT to get the coat hanger through but they do! Just shine a bright light into the hole behind the wheel to prove it. Have fun with that!
After you get your coat hanger through to the other side drill a 5/8" hole in the seal for the wheel well and pull it over your power cable. Bend about a 1/4" of the end of your coat hanger that's now outside. Push it into the bare end of the power cable and into the insulation to make pulling the cable as easy as possible. Pull it through to the other side.
Drill a hole in the other seal and pull it over the power cable anp Pull everything tight. At this point the cable will be exposed to a little bit of road debris (but you still can't see it from outside the car without getting under) The NS-Kit I bought at frys had some plastic cable covering, trim it to length for the section that is behind the wheel and wrap it up. The insulation on this high gauge wire is really enough to protect it but this is just an added bonus.
At this point you have the cable in the cab! YAY! The wire harnesses that hold the stock wiring will have plenty of space for this power cable all the way back to the left passenger seat. (you'll need to now remove the panel right behind the driver seat and also the passenger kick panel and set them aside, again everything just snaps off, they wont break)
Pull the power cable through each one of the white plastic harnesses and then snake it, with your hanger, up under the passenger seat and into the trunk (note, I have a 60/40 split in my rear seats which made this very easy but if you don't have that I don't know what to do) THAT's DONE! You now have power!
Next you need a signal for your amp:
The signal going to each one of your speakers is amplified! You'll need one of these
which is a line out converter that will drop the amplified signal down to line voltage so you can safely run it into an amp. Since we're just installing a sub and and amp we only need on side of the signal because the low end is usually not split stereo wise.
The next step is to locate the group of wires that run up from the kick plates and into the left rear passenger door. The group of wires, if your now looking from the rear left passenger seat, runs up from inside the car and travels through a rubber tube and into the door. We're going to splice into the wires for that door's speaker on the inside.
They will be taped to a wire harness that is secured to the frame right next to the driver's seat belt. You're going to need to expose about 2-3" of wire in order to splice into it, so cut some of that tape off to do this (BE CAREFUL! these wires are very thin and control your locks, window and speaker in that door)
Now that you have a length of wire to look at, locate one green and one yellow wire that are marked every inch or so with silver. These are the speaker wires, YELLOW +, GREEN -. With a wire cutter/crimper and some wire splices take some 16-20 gauge wire and splice in two lengths, one for each speaker wire (long enough to get to the trunk). Run both wires straight down and then follow your power cable to the trunk. Since this is just one channel (which is fine) wire into one side of your line out converter that is best placed in the trunk. Now you have an RCA output for your amp!
The only thing you need now is a remote wire.
Since you want your amp to turn off when the car is off you need a 12v power signal that is off when the car is off. The way I got this was to run the included remote wire into the fuse box that's up under the steering wheel. To do this, take out the fuse for the cigarette lighter. (this fuse is off when the car is off and on when the key is turned to ACC or ON) Strip about 1/4" of the wire and push it into the top leg of the hole for the cigarette lighter fuse (look at the diagram on the door for the fuse box to find it, it's kind of confusing though ). Your remote wire should be about 20 gauge wire so you should be able to just push the fuse back in to the slot to secure everything. Snake it down through all the wire harnesses and back to the trunk like your power wire.
Now you have all the elements of a basic setup that you need to hook up any amp/sub setup. Securing an amp can prove a little tricky but it's only limited by what you want to drill into your car and the bottom of your trunk. (but be sure to file away any paint for where ever you decide to hook up your ground wire)
Also, be sure to get an RCA splitter for your amp so that you run the same mono signal for both RCA plugs on your amp.
Now put on the music you most listen to and adjust levels to taste! (but keep the gain on the line out converter as low as possible to keep your amp from clipping)
I personally hooked up a 1000w amp and a 12" sub with a 1.5f Capacitor and it flippin' bumps!!!
Again, I apologize for the lack of pics. Feel free to ask about anything that's confusing 'cause I just did this and am very happy with it.
GOOD LUCK!!!
GOOD LUCK!!!
mrwickd123
Evo X How Tos / Installations
30
Feb 20, 2019 09:29 PM
Murch
68
Sep 8, 2014 04:29 AM
03chi-town0Z
41
Jan 2, 2014 05:04 PM
gunvalk
Lancer How Tos / Installations
Feb 24, 2010 09:00 PM
