How-To Automatic Transmission Flush
Hey guys, I"m pretty new to this, i've read in some forums outside of this that you have to take off the cover should i take off the cover and clean it out?
thanks in advance!.
thanks in advance!.
they do have filters but it is not the easy to get to the filter, and when checking the a/t fluid make sure the car is in 1-correct temp 2-the engine running,and car has to be on neutral(N) when checking dipstick,and of course a flat surface..
Just for some extra info -
You do NOT need to change the filter. ever.
It is not like an oil filter. Oil filters are necessary to catch all the garbage brought into the oil including the residual muck from combustion in the cylinders.
Instead, the transmission is a closed system. The filter is a metal screen that catches large debris like remnant from the casting.
If this metal screen were to ever become plugged up, then there would be far worst issues in the transmission that would require attention rather than just a simple 'filter' change.
chaotichoax
32
Feb 11, 2020 09:00 PM
SleepySamurai13
Apr 28, 2017 05:04 AM
clifhanger87
46
Oct 30, 2016 07:11 PM
junk1337
Evo X How Tos / Installations
60
Jul 22, 2016 03:27 PM
