Console Lights All-In-One How-To
Now you'll understand why the gauge cluster had to be loose. Starting from the left, begin to pry the vent panel up and outward. Don't worry if little white clips start flying everywhere, you can re-attach them back later.
So you want to take this one step further? Undo the clear part of the gauge cluster. There are two clips holding it in at the top, gently push down to release the face.
Now that the gauges are exposed, gently pry out the needles, remove the gauges, and replace the two bulbs shown. I didn't finish this part, because I left mine the stock colour.
If you've paid attention, now is the time to reverse all the removal and unscrewing, and get your dash back to normal. For the climate controls, if you've done everything correctly, the light guide should look like this:
