How To: Install a Evo X ecu on a NA Lancer.
#31
i've developed the ability to disable any and every CEL for Mitsubishi CAN based vehicles, including lancers, outlander, RA, Evo X, and of course, a lancer with Evo X turbo. It requires one of my custom ROMs and tuning.
#33
RALLInspired - I tried contacting RRE a few weeks ago and they told me they couldn't do it remotely? Just wondering, how much for a fully custom tune for a 2010 RA 9psi turbo setup on a 2010 Lancer ES 5 speed? I mean base map plus a few pull corrections (remotely)? Which codes are you referring to? MIVEC EX, IAT, Boost solenoids...?
Thanks for everyone's help!
#38
Cant, tune my Lancer
Grettings
I have a Lancer Turbo with Evo X Rom on it. I buy tactrix cable and download ecuflash. Cant read the ecu for tuning because said (unkown rom image). I have a 2009 ecu.
Anyone can helpme with this problem?
Im new in this. Please help
#39
So you have boosted your lancer...
With the MUT-III, copy the ECU Coding from the Lancer to the PC. To do that, you have to clear the DTCs, if there is one DTC, it will not work. I had to install the IAT sensor because the P0098 was always there and I wasn’t able to clear that code. The P0243, P0242, P0365 can be cleared and if you don’t start the car, they will not show up.
I wanna clarify this P0098 issue bcos in another turbo build it wasn't an issue when he swapped to EvoX issue.
1. Am i correct that you had this code when you flashed an EvoX rom on your NA lancer ECU?
2. Noob question, where and how did you put the 2nd IAT sensor? I can't find a guide on lancer turbo threads.😅
#40
#41
before he relearned the keys to the car
