Lancer How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in in the Request sub-forum.
How To install an OEM Evo X Front License Plate Bracket
Old Jul 18, 2016, 08:07 PM
FiReBReTHa's Avatar
Pics dont work! I have to move them over to a new host! I just needed to copy the info over before I lose the write up.
Things you will need;
Drill
Phillips screwdriver
13MM drill bit (Must have, go out and buy)
3/32 drill bit (negotiable, anything small for a pilot hole)
OEM bracket
Second set of hands makes this project easier
Here is what comes with a license plate bracket from an 08 Evolution.
Bracket, 3x rubber compression screws, paper guides.
I used my second set of hands to slide the bracket left and ride to find where the bracket’s curve lines up with the car.
Put a little bit of pressure on the bracket to keep it against the car to see how it will install smoothly.
Once I found the exact position I then drilled a pilot hole on the hole all the way to the left.
Then use the 13MM drill bit and fit the rubber piece into the hole.
Then place the bracket over the rubber and then insert the Phillips machine screw and tighten it, this will compress the rubber and secure the bracket to the car.
Final product!!!
NinjaX
Apr 25, 2017 08:19 PM
Evo_Goodness
Aug 7, 2016 09:52 AM
HarEvo
May 26, 2009 08:43 PM
dorian7
Dec 17, 2008 08:07 AM
Quick Reply: How To install an OEM Evo X Front License Plate Bracket
