Pioneer avh2800bs VS Metra 70-7001
I recently purchased a Pioneer double din the AVH 2800bs i moved the climate controls so everything can fit installed the dash kit but i can't seem to figure out how to wire the radio harness onto my metra harness if anyone knows how to do this your help would be greatly appreciated
What are you having trouble with? Colors basically match from harness to harness. You will need to run your own ground as the OEM harness doesn't supply one. If your talking about how to physically connect the two harnesses you can use crimp connectors or solder them together and heat shrink. There are some wires you will have to run yourself that aren't going to be in the metra harness, like the parking brake etc.
Xcited
Jul 1, 2009 09:50 PM
bluewaterDEMON
17
Dec 24, 2008 12:49 PM
