The big Mirage-Lancer thread
#31
I figured that, but I was speaking more along the lines of will it fit in the engine bay ok or will there be rubbing on maybe the bumper or anything. Height is no problem, I would be getting the rest of the exhaust custom fit onto it.
#38
I heard suspension is the same between the Lancer ES and Mirage.
Does that mean I could put on the KYB AGX Adjustable Shocks & Struts, for the Mirage?
I have a set of TEINs and Im gonna use 'em. RRM's replacement for the Lancer, are the GR2's I believe, and I read that their not much better than stock..
The AGX's are KYB's performance Shock setup.
Can I use 'em & benefit, on my '03 ES, with TEIN S-Techs?
KYBs AGXs
KYBs GR2s
RRMs KYB GR2s
KYBs AGXs
KYBs GR2s
RRMs KYB GR2s
#39
As posted previously, I'm not sure. No one has stated 100% that they will fit. If you try, please let us know.
As for shocks, the AGX are far better than the GR-2. I'd highly recommend the AGX if you can get them.
#42
Correction.
The Mirage has the same bolt pattern as the Lancer. 4 X 114.3
I had a set of rims that I was going to use from my Mirage when I bought the Lancer and they fit perfectly. I had low profile tires on the rims though so it did not look right thus I never used them.
I had a Mirage 2 door DE coupe.
WADAD
WADAD
#44
Correction.
WADAD
WADAD
All US Mirage from 94-02 have 4 x 100 bolt pattern
In '99 they started to have the bigger 256mm rotors on LS models and
in '01 all models had the bigger 256mm rotors.
#45
I checked over on the Mirage boards and they seem to confirm this.
I guess the rims I had which were double drilled for both 4x 100 and 4x 114.3 played a part in my error but I swear I used the same holes for mounting the wheels.
WADAD
