Brakes
Originally Posted by Alchemist
since most of the parts in that link start life as 4x114.3 it seems like a good fit for OZs- if you're willing to put in a lot of work on parts that won't add much to performance.
But most of the people upgrading their brakes DON'T know that. And they won't listen to us - "bigger is better" they say.
Originally Posted by Blacksheepdj
I know that. And you know that.
I wont be upgrading the rears at all or to a bigger kit (more then likely) as a nice set of rotors and pads are all you need on the lancer. However that double piston caliper i think would be nice.
Main point is... YOU CANT STOP FASTER THEN YOUR TIRES ALLOW NO MATTER HOW BIG OF BRAKES YOU HAVE!
post thought... just b/c you are turbo doesnt mean you need bigger brakes, power has nothing to do with the need for bigger brakes.
Originally Posted by Evo666
hey im just giving info for those who wants it.
If you guys don't want to do a brake swap then don't even bother posting here.
Please post something useful.
My point is let them do what they want to do with their money.
if i had the cash i would blow it on some new brakes but i dont.
like you said though its their money...
so RPW makes a rear disc brake conversion for our lancers...but my question is that can I just source the parts myself?
I need mirage calipers and mirage rotors. Obviously brake lines and e-brake hardware.
What about the brake caliper bracket?
Sorry if this stuff seems beginner but i'd much rather do this myself even if really doesn't make a difference like some people are saying...looks way cooler than drums.
thanks
thanks
I appreciate the honestly but still I would like to understand how the kit goes together...sometimes people get lucky and come across a good car on ebay or in the local junkyard.
Can anybody chime in on how the kit is brought together...what parts from the mirage do I need?
thanks
thanks
Thanks for the suggestion...but my question is that since I have an OZ I'd rather not do the redrilling...I want a full swap over...just parts
What rotor do I use now that has the 4 x 114 pattern? Also the 2 piston caliper that RPW is using on their front and rear kit...what car is that from? I am assuming i just use the caliper bracket from the new caliper and that will bolt up just fine?
What up the parking brake assembly?
I know this has been probably discussed before but since we have this new forum, might as well have a full knowledge transfer
