Lancer-Mirage Compatibility Forum For parts that can be used on both Lancer & Mirage models, post/look in here.
Brakes
Old Aug 11, 2006, 10:38 AM
Blacksheepdj's Avatar
Brakes
First off, do you really need a big brake kit or rear discs? You might only think you do.
If you're driving and ES (or any model with 4x100 lug pattern), you can make use of kits for the Mirage (or the DIY stuff Mirage guys do).
2g Eclipse GSX front brakes
here is a helpful How-to from Mirageforums.net
http://67.15.109.176/phpBB2/viewtopic.php?t=3813
Of late, RPW has begun to offer kits specifically for the Lancer, making the need to use Mirage parts less important. Wilwood has a kit as well.
Rear disc conversion for Mirage/Lancers
Front upgrade for Lancer/Mirage
Wilwood kit for Lancers with 4x114.3
Dynalite Big Brake Front Hat Kits:
Forged Billet Dynalite 4 Piston Caliper
Available in Red, or Black
11.00” and 12.19” HP or SRP
Performance Rotors
GT Series Aluminum Hats
Performance Brake Pads
ABS Compatible
Old Aug 12, 2006, 09:26 PM
Evo666's Avatar
A cheaper option is to use 2g Eclipse GSX front brakes
http://mirageforums.net/viewtopic.php?t=3813
Old Aug 14, 2006, 11:46 AM
There we go. That's the kind of helpful stuff I was looking for. I'd be damn embarrassed if this thread stayed with my one post!
Old Aug 14, 2006, 12:49 PM
Alchemist's Avatar
since most of the parts in that link start life as 4x114.3 it seems like a good fit for OZs- if you're willing to put in a lot of work on parts that won't add much to performance.
Old Aug 14, 2006, 01:03 PM
Kurt's Avatar
Would it matter if you were using a rotor such as the Brembo slotted and pads such as the Axxis Ultimate instead of stock Mitsubishi parts? Also, after reading some of this and you raising the point that they might be a good fit for the OZ, I wonder if that kind of setup would clear the factory wheels.
Old Aug 14, 2006, 05:02 PM
Evo666's Avatar
if your factory wheels are 15" and above it will fit.
If you get the 92 galant vr4 rotors, they are 4x114 so they should fit on OZ without modification to that.
A good place to find 2g Eclipse GSX calipers is car-parts.com
Old Aug 14, 2006, 05:21 PM
03RallyLancer's Avatar
will these calipers mount up w/o a new bracket on the front? and can we re-use are lines?
Old Aug 14, 2006, 06:04 PM
revolt4revolver's Avatar
now heres the ? what mitsu rear discs fit the lancer.
Old Aug 14, 2006, 06:12 PM
rhyzin's Avatar
if you got an OZ/LS, get the rear RA discs redrilled to 4x114 since they start off as 5x114. then swap over the rest of the hardware.
Old Aug 14, 2006, 06:16 PM
does the RA have ABS?
Old Aug 14, 2006, 06:18 PM
rhyzin's Avatar
yes. why?
Old Aug 14, 2006, 06:20 PM
what would you do about the abs stuff on the rear caliper? sorry dont know much about how abs is setup.
Old Aug 14, 2006, 06:27 PM
rhyzin's Avatar
just don't install it. it'll just be a gear that bolts to the rear hub while the sensor is somewhere in the drum. or you can keep it on. it doesn't matter since you won't have a sensor, unless you're an LS.
Old Aug 14, 2006, 06:32 PM
now the only problem is sourceing it all now... that wont be xpensive at all.
Old Aug 14, 2006, 07:01 PM
Evo666's Avatar
you would have to use the eclipse caliper mount. For the brake lines, a mirage can reuse theirs not sure about you guys. Also the mirage can use 2g eclipse gsx brake lines. Just a thought for you guys if you want to upgrade to those braided stainless steal lines.
Quick Reply: Brakes
