Lancer-Mirage Compatibility Forum For parts that can be used on both Lancer & Mirage models, post/look in here.
mirage cam on 4G94
Old Dec 31, 2007, 06:06 AM
Jehuty's Avatar
do a write up of the throttle body, you'd become my best friend
Old Dec 31, 2007, 07:39 AM
Mirage4g93's Avatar
What do you need to know about the TB swap?
Tools:
12mm deep socket for TB bolts
8mm socket for TPS screw/bolts (recommend socket b/c screw portion strips easy)
Pliers will help for removing retaining rings on coolant hoses
PB Blaster for removing hoses as they may be stuck on
Scan tool or multimeter for calibrating TPS
Process:
Get a 1g Not Turbo throttle body. That way you don't need an elbow.
Remove negative battery terminal from battery
Unplug your tps by taking the U shaped clip off and pulling the harness off the sensor.
Remove the 3 vaccum hoses from the tb
Unbolt the 4 throttle body bolts.
Remove the throttle cable from the TB
Unclip the coolant hoses and run the two coming off the motor together to return the coolant to the motor
Get a piece of coolant hose the same size and attach to both ends of the tb to bypass the tb.
Get a 2g DSM TPS and attach to the 1g DSM tb.
Get a 1g DSM Gasket
Clean both the IM and the 1g DSM tb so the gasket gets a good seal.
replace the stock tb with the 1g DSM tb and bolt 4 tb bolts
connect 3 vaccum hoses to respective nipples on the 1g tb
Connect TPS harness. Place U shaped clip on TPS to hold harness.
reconnect negetive battery cable to terminal to battery
Calibrate TPS with scan tool
Let car idle so ECU can learn settings again. Go drive
Old Jan 1, 2008, 01:25 PM
Mystic_Korean's Avatar
I think 97-99 are solid.
99+ are hydrolic.
That's why it wasnt a direct bolt on.
Old Jan 1, 2008, 02:20 PM
Noe18's Avatar
is 99 cam would be a direct drop on a 03 lancer es without changing valetrain????
Old Jan 7, 2008, 08:08 PM
arptunner's Avatar
I sold the mirage 272 cam and valvetrain. I couldnt stand the shaking of the car . it was always shaking it never staid still , that cam profile is way too agressive for street use specially a new car. installed the stock back on and will go on with the turbo seup. still getting the parts, maybe I'll get a microtech stand alone so I can fine tune the car so there wouldnt be any regreats with the turbo setup
Old Jan 8, 2008, 04:57 AM
Jehuty's Avatar
Tools:
Process:
Get a 1g DSM Gasket
Man.....I feel like an idiot, lol. I read about it on the mirage forums, and they made it seem like you needed the frikin president of mitsu to be there with all the directions that they had, thanks though bro good "write-up" lol
Old Jan 8, 2008, 12:36 PM
Tech@SA573's Avatar
What voltage does the TPS need to be set at?
Old Jan 8, 2008, 03:17 PM
Mirage4g93's Avatar
I don't have it off the top of my head but there is a how to and diagrams on it over at www.mirageforums.net
Old Jan 9, 2008, 05:53 AM
Mirage4g93's Avatar
oh and in my little write up i forgot to mention to reconnect the throttle cable lol you'll need that.
Old Jan 9, 2008, 08:09 AM
Mirage4g93's Avatar
here is a link to the DSM TPS adjustment how to from www.mirageforums.net
http://www.mirage-performance.com/te...Adjustment.pdf
Follow that to calibrate your TPS.
Old Jan 9, 2008, 04:16 PM
Tech@SA573's Avatar
Thank you... /threadjack
Old Jan 17, 2008, 04:10 AM
mirage 4g93t's Avatar
i guess imma keep my mirage cam..haha
justboosted02
76
Oct 2, 2019 04:02 PM
Live4Redline
Lancer Engine Tech
19
Jan 9, 2017 09:55 PM
Demon_ni2
May 19, 2012 05:43 PM
Supa tek
Lancer Engine Tech
Feb 7, 2007 02:52 PM
TTOPPOUZI
Feb 6, 2007 06:25 AM
Quick Reply: mirage cam on 4G94
