Stock Exterior/Interior Bulb Replacement
Old Oct 5, 2003, 10:49 PM
  #31
nightrider's Avatar
damn i bought the red #74 led's and they arent bright at all. the regular bulbs that i replaced them with are brighter. damn i thought led's were suppose to be bright as hell..oh well guess ill order the regular red 74 and see how they do.
Old Oct 6, 2003, 09:18 AM
  #32
lancer02Josh's Avatar
its not as much as there not brighter but they shoot the light straight ahead instead of a wide beam. so the plastic that disperses the light throught the buttons doesnt light up as much
Old Oct 6, 2003, 09:09 PM
  #33
drummerjun's Avatar
ok, so I bought a couple 74's..
and turns out....the STOCK CD PLAYER DUN USE 74 BULBS!
they are much much shorter and smaller than 74's and I've no idea what they are....
Old Oct 7, 2003, 11:46 AM
  #34
psionic98's Avatar
that sucks man, did you try to see if one would fit and the buttons would still be able to be pushed and stuff?
Old Oct 7, 2003, 04:55 PM
  #35
psionic98's Avatar
is the highmount brake light also a 7443?
Old Oct 8, 2003, 12:55 AM
  #36
zstryder's Avatar
Are you sure the dimmer light is a 74? I know I have an Evo but it looks to be a bit smaller..
Old Oct 8, 2003, 01:13 AM
  #37
drummerjun's Avatar
check the first post...
i edited it..
it doesnt use 74, is smaller and shorter, same as the stock cdplayer...
Old Oct 8, 2003, 01:50 AM
  #38
zstryder's Avatar
Do you guys have 3 dome lights on your cars too? I'm wondering if the LED dome lights or the normal bulbs would be brighter?
Old Oct 8, 2003, 10:00 AM
  #39
psionic98's Avatar
normal would probably be brighter, but leds would look nicer IMO
Old Oct 8, 2003, 06:14 PM
  #40
zstryder's Avatar
Say, how do you get to the domelights on the car? Do you take out the entire housing, or do you just pry off the clear plastic part that covers the bulbs?
Old Oct 8, 2003, 06:19 PM
  #41
BlackLancer2k2's Avatar
pry off the plastic piece, and also the led's are brighter,but normal bulbs are more of a light spread, so with led's it's more of a focused light..white would probably be the only color where you can actually manage seeing anything in the car if you decide to change out the dome light
Old Oct 9, 2003, 05:37 AM
  #42
psionic98's Avatar
unless you dont ever care if you use your dome light I wouldnt use leds, only because we only have 1 dome light... like blacklancer said, its brighter but only in like one spot, and thats where teh light is focused, even though the clear diffuser is there, it still wont make the light come out anything like a filament bulb... but if you dont care about using it I think led would look sweet in there
Old Oct 9, 2003, 05:43 AM
  #43
Kyperion's Avatar
what size are the fog bulbs
Old Oct 9, 2003, 05:44 AM
  #44
our regular lancers don't have fogs
Old Oct 10, 2003, 07:56 PM
  #45
sicx13's Avatar
Talking light bulbs for instrument cluster!
anyway after searching and reviving old threads and still no answer, i took it upon myself to take my cluster out and find out for myself anyway i found a direct replacement for the dash bulbs. the T1.5 Instrument LED bulb on http://www.superbrightleds.com/cgi-b...gi?product=CAR fit the cluster (i have only one in blue) but i treid it on the gas/temp gauges and it looked good with pretty even light distribution and i trie it on the lcd screen for the odometer OMG it looked good to see a nice shade of blue insted on green( it was VW like.
Quick Reply: Stock Exterior/Interior Bulb Replacement
