Console Lights All-In-One How-To
Old Mar 5, 2004, 04:57 PM
jtc
jtc's Avatar
Unscrew these two screws holding the knob controls to the face plate.
Old Mar 5, 2004, 04:58 PM
jtc
jtc's Avatar
With your fingers in the holes, pull out with even pressure to remove the face plate.
Old Mar 5, 2004, 04:59 PM
jtc
jtc's Avatar
Unscrew these 4 screws, holding in the light guide and the Defogger/AC/Recirc buttons.
Old Mar 5, 2004, 05:01 PM
jtc
jtc's Avatar
Removing the light guide and buttons should give you clear access to the two bulbs you need to change.
Old Mar 5, 2004, 05:02 PM
jtc
jtc's Avatar
Now for a more tedious task, getting at the clock. First, remove these two screws holding the vent panel in.
Old Mar 5, 2004, 05:03 PM
jtc
jtc's Avatar
Now you'll understand why the gauge cluster had to be loose. Starting from the left, begin to pry the vent panel up and outward. Don't worry if little white clips start flying everywhere, you can re-attach them back later.
Old Mar 5, 2004, 05:04 PM
jaymz916's Avatar
where do you get the bulbs from? What color, orange or red?
Thanks, looks nice.
Old Mar 5, 2004, 05:05 PM
jtc
jtc's Avatar
It's a little scary to look at, but here's what you end up with. Disconnect the two cables for the clock and hazard lights.
Old Mar 5, 2004, 05:07 PM
jtc
jtc's Avatar
Now you have access to the clock piece. Four tabs, two at the top and two at the bottom hold the clock in. Gently undo these to release the LCD.
Old Mar 5, 2004, 05:08 PM
jtc
jtc's Avatar
The red clock mod requires two piece of coloured filter. The first one I taped directly onto the LCD.
Old Mar 5, 2004, 05:10 PM
jtc
jtc's Avatar
The second piece which deepens the colour even more is just dropped in to the clock housing. Without this piece, the clock turns orange. Yuck.
Old Mar 5, 2004, 05:11 PM
jtc
jtc's Avatar
At this point, your dash looks pretty messed up. Let's hope you remembered where all the screws are and can put it back together.
Old Mar 5, 2004, 05:12 PM
jtc
jtc's Avatar
So you want to take this one step further? Undo the clear part of the gauge cluster. There are two clips holding it in at the top, gently push down to release the face.
Old Mar 5, 2004, 05:13 PM
jtc
jtc's Avatar
More clips at the top and bottom hold the black plastic face in. I guess at this point you could remove it for a paint job also.
Old Mar 5, 2004, 05:15 PM
jtc
jtc's Avatar
Now that the gauges are exposed, gently pry out the needles, remove the gauges, and replace the two bulbs shown. I didn't finish this part, because I left mine the stock colour.
Quick Reply: Console Lights All-In-One How-To
