Tire Pressure on a 16 inch rim
I have 16 rims with 205 50 16 tires on them. They are currently at 30 psi, but that's the factory psi setting for factory tires. On the tire it says 45 PSI Max, but doesnt give the a psi rating on what it should be. Any thoughts?
205/40/17 im running 35-40 psi tire says 44 max so i put 40 but jack williams auto said 35 is fine to use. i just go higher so if i hit a pothole the tire cant flex enough to dent my wheels. i would go w/ 35 cause you have a thicker tire and dont need high pressure to save your wheels.
Kayvee413
Oct 24, 2017 06:07 AM
JasonByeon
May 10, 2016 09:35 AM
Evokid03
Jan 22, 2010 10:35 PM
chrls000171
23
Feb 4, 2005 01:50 PM
