Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Official Wheel/Tire Info Thread
Old Dec 19, 2007, 06:32 PM
Stuntfly02's Avatar
No they will not fit. 215 is width of tire. 45 is height of sidewall. the 45 stands for the sidewall=45% of the tires width. so even though those 2 numbers are the same the 17 means that the tire itself is an inch smaller in total diameter. You will have to get 215/45/18 snow chains.
Old Dec 20, 2007, 10:28 AM
Blacksheepdj's Avatar
Stuntfly02 is correct - you have to get the correct size. You can't fudge this.
Old Dec 20, 2007, 11:00 AM
ustcc evo's Avatar
I'm running 235/45-17 on stock Evo 17x8 rims, 38mm offset. I had to roll the rear fender lips on the Lancer to make them fit, though my car is lowered over 3". The fronts also rubbed against the front of the fender liners, but it fit well by the end of the race...the tire wore away holes in the fender liner quite nicely.
Old Jan 21, 2008, 10:53 PM
LancerGTS's Avatar
I have 18x8 wheels with 235/40R/18 wheels.
This is with the WORKs springs that have a 1.1 drop.
No rub issues even during autocross, turning hard and hitting the brakes.
Old Jan 22, 2008, 08:18 AM
Thanks LancerGTS. I updated the first post.
Old Jan 22, 2008, 08:59 AM
stefan.bounket's Avatar
I've read through a few forums now.. and none seem to mention if the rim width matters etc and how much
So im just wondering... I'm looking to buy winter tires/rims and trying to save money by buying smaller rims with bigger times (bigger sidewall so that the wheel overall is roughly the same diameter)
We all know the stock GTS rim is 18x7... but how big of a difference does the width make?
ie) would a 16x6.5 rim fit? also.. for these types of patterns..
a) Pattern: 16 X 7, 6-5-1/2.
b) Pattern: 16 X 6-1/2, 5-115.
c) Pattern: 16 X 6-1/2, 5-4-1/2.
d) Pattern: 16 X 6-1/2, 5-100.
does the bolt pattern have to be EXACTLY the same for it to fit properly?
Which of these rims would i be able to fit on the GTS?
If more than one fits.. are any better than the others? or about the same... (the 16x7 rim is about double the price of allt he others )
Old Jan 22, 2008, 11:25 AM
Stuntfly02's Avatar
c) Pattern: 16 X 6-1/2, 5-4-1/2 is the ONLY one that will fit. The bolt pattern has to be EXACTLY the same. The ONLY thing you can play around with is the offset. Seems a 35mm to a 45mm offset will work. Im not sure anything else has been tried.
Old Jan 22, 2008, 11:44 AM
alright. thanks =)
makes me happier in that i now know as well as those are the cheapest rims. hahah
Old Jan 25, 2008, 11:25 PM
lostkidd2's Avatar
is the offset for the ES 46mm also?
Old Jan 26, 2008, 11:51 AM
That is my understanding, yes.
Old Feb 23, 2008, 11:36 AM
LancerGTS's Avatar
Anyone know if there are torque specifications for our lug nuts? I searched a bit but didnt see anything. I know the last model Lancer was around 75.
Edit: And ours is the same. *cough* owners manual *cough*
<--- Nub
Old Feb 23, 2008, 06:29 PM
gtslancer08's Avatar
im thinking of getting the work emotion cr's in bronze and i see the stock offset for the oem wheels are 46mm. i only see that this wheel will come with a 42 mm or 48mm offset, just wondering should i go bigger with offset or smaller. thanks
Old Feb 24, 2008, 03:31 PM
<--- Nub
Official FSM answer is 73 ft-lbs, plus or minus 7 (so anywhere between 66 and 80 is cool, according to ).
Old Feb 29, 2008, 12:51 AM
limmerZ's Avatar
would 18x7.5 size rims fit with 215/45/18 tires? the stock gts is 18x7 says on the first post....but i duno wut the 7 means so im wondering if the .5 extra affects nething.. thnx
Old Feb 29, 2008, 06:26 AM
Should fit fine, yeah. The extra .5 just makes the rim a little wider. Since you'd be using stock size tires, it'll just give them more room to breath.
Quick Reply: Official Wheel/Tire Info Thread
