Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Official Wheel/Tire Info Thread
Old Mar 1, 2008, 02:25 AM
  #31
limmerZ's Avatar
hrmm icic. well i wasnt gonna put the rims on stock tires. juss i thought if i were to get sum better performance tires, i thought i'd stick wit the size of wut the gts was running on to be safe? im not really knowledgeable on wheels/tires so thought i'd get sum help from here =p basically im wanting 18x7.5 rims on sum good low profile tires. soo would i have to stick wit the 215/45/18? or is ther another tire size that would fit the rims and be low profile? thnxx n sorry if this doesnt belong in here =[
Old Mar 2, 2008, 11:09 AM
  #32
Blacksheepdj's Avatar
I said "stock size" not "stock" . . . You don't HAVE to keep the stock sizing, but it's a good idea. Should fit fine, and the speedo will stay correct.
45 is low-profile enough if you ask me. Lower than that, you risk horrible ride quality and popping tires when you hit potholes.
Old Mar 2, 2008, 01:55 PM
  #33
limmerZ's Avatar
hrmm alrite thnxx. i'll stick wit 45 then. thnx alot =]
Old Mar 3, 2008, 08:49 PM
  #34
DaMan05's Avatar
Originally Posted by DaMan05's Bro
Well I wouldn't have to make the effort if I found out they didn't. Plus they are on another car, i was planning on buying a replacement for that car and using the present ones for the Lancer. Besides you can add it to your sticky on top I found the info. Majority of 5x114.3 bolt pattern steelies with 67.1mm centre bore will fit. This was verified by a canadian online tire dealer and tire rack. So most hondas and mazda steelies will work. Some old toyota jeeps might not, offset is not close. This info is mainly for people going to the scrap yards which will save you 50-75% of the cost of steelies. Most online shops due not have the info for 2008 models, and this is handy info. Mazda3 specific steelies are the same for the Lancer.
WOW lol... i didn't even know my bro posted here... lol i was surprised when I saw that
Old Mar 19, 2008, 01:41 PM
  #35
AJsGenerX's Avatar
I'm looking to purchase these wheels in gold for my Graphite Grey GTS. I can't determine what size and offset to use to ensure a proper fitting. I was thinking 18 x 7.5 with a +45 offset. Does anyone know if this will fit?
http://www.gruppe-s.com/Advan/advank10i.htm
Old Mar 20, 2008, 08:56 AM
  #36
Yeah, that'll fit perfect. That's very close to the stock GTS wheel size, so I'm 100% sure it'll fit on any 2008 Lancer.
Old Mar 20, 2008, 11:50 AM
  #37
AJsGenerX's Avatar
Thanks Doug.
-Ankur J.
Old Mar 24, 2008, 07:06 AM
  #38
fusion04's Avatar
has anyone tried to go a little wider and put 225-45-18 on the stock rim?
is this even possible?
Old Mar 24, 2008, 02:59 PM
  #39
Should be fine. It's not too big a change. But you probably want to drop the profile a bit to match.
I have a set of 225/55/16 tires to go on, and I've heard they "should" fit OK. TireRack seemed to think they didn't, but some EvoM folks said they'd work.
Old Mar 30, 2008, 09:19 AM
  #40
torockus's Avatar
I was thinking of getting rims, and wanted to know if 18x8 with offset of 40 fit? and if it does would 215/45/18 tires fit on them?
Old Mar 30, 2008, 01:08 PM
  #41
Should fit OK. Only 1 inch wider than stock, so I don't see a problem. The tires should stretch to fit.
+40 is getting close to the edge, though. If they hit the calipers, be prepared to buy some spacers.
Old Mar 31, 2008, 06:01 AM
  #42
torockus's Avatar
Thanks for the help
Old Apr 5, 2008, 12:06 PM
  #43
AJsGenerX's Avatar
The GTR concavity face on Advan racing wheels have a minimum with of 8.5 inches. I dont think this will sit well with our cars. The offset and bolt pattern are perfect but I think the rim size will cause a rubbing issue. Anyone able to slap on an 8.5 inch wide wheel?
Old Apr 12, 2008, 12:36 AM
  #44
ashun22panda's Avatar
as for buying new lug nuts.. all that matters is that the Lug nut thread/pitch - 12 x 1.5 is the same right?
do we have to match the Lug pattern is 5x114.3 too?
Old Apr 13, 2008, 11:39 AM
  #45
Lug thread and pitch is all that matters BUT you have to make sure they match your wheels. Different wheels have different lugnut surfaces - flat, slanted, rounded, etc.
As for the lug pattern, the only part that matters for lugnuts is the 5 half. Because it means you have to make sure you buy 20 lugnuts.
Quick Reply: Official Wheel/Tire Info Thread
