Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
Official Wheel/Tire Info Thread
Old May 21, 2008, 08:21 AM
  #61
KaizLancer's Avatar
Thanks BlackSheep!!!
Old May 21, 2008, 10:41 AM
  #62
Blacksheepdj's Avatar
Originally Posted by LuDa
would increasing them to 19s make any diff? as far as rubbing issues and such goes? or just the with is what matters..
ive seen 18x9 on a ES before..dont know how many problems they had
but i guess the only way to find out is to try them on i would guess..
19" shouldn't matter. It's all about the width and tire, honestly.
Pretty much, yeah. Unless you track down the 18x9 guy and ask him.
Glad to help!
Old May 22, 2008, 01:20 PM
  #63
YeOldeLancer's Avatar
So I asked TireRack if rims for a DE or ES would fit my GTS (09) and he said it wouldn't. Would this size fit?
Offset: 40mm
Bolt Pattern: 5-114
Tire size: 215/50/17
Old May 22, 2008, 03:19 PM
  #64
Offset: 40mm
Bolt Pattern: 5-114
Did they say why? DE/ES rims should fit perfectly. I hadn't heard anything about changing the wheels/brakes/etc...
Old May 22, 2008, 10:12 PM
  #65
no he didn't say why. Maybe he just saw that there wasn't a 2009 Lancer GTS listing on their website and stated that they wouldn't fit...
I'm assuming they would fit right? since a search on an 08 Lancer GTS yields the same bolt pattern and offset...I will inquire again as winter nears....
Old May 23, 2008, 01:35 PM
  #66
I'd guess it fits just fine. Probably just an ill-informed customer service rep...
Old May 25, 2008, 12:18 AM
  #67
fsdork's Avatar
I bought 16" steelies for my winter set, and had no issues. I had heard the DE/ES rims wouldn't fit over the GTS brakes, but it wasn't a problem on mine.
Old May 25, 2008, 01:51 AM
  #68
LuDa's Avatar
is there any websites out there or some kind of website that has Faqs about wheel sizes and such
Old May 25, 2008, 07:02 AM
  #69
08Lancer89's Avatar
what size 19's will work without any issues how wide can I go
Old May 26, 2008, 10:30 AM
  #70
so has anyone confirmed if a 225/45/18 tire would work on a stock GTS rim that is 215/45/18. I would imagine it would....
Old May 30, 2008, 10:12 AM
  #71
ritalinfit's Avatar
Wheel Size?
I looked through the thread and didn't see it, but is there anyone running a: 17x8 wheel with either 235/45/17 or 225/45/17 tires without any issues?
I saw that someone was running 18x8s in the same configuration alright, but does that mean 17s will fit by default?
Old May 30, 2008, 03:00 PM
  #72
dklau33's Avatar
Yes, back on post #18, the poster stated he was running stock evo 8 wheels that are 17x8 +38 with 235/45/17 tires. It was rubbing in the front and the rear fenders had to be rolled but then again it was a NASA racecar that was dropped significantly. On a normal or a mildly dropped Lancer I think this is about as far as you can go without rubbing issues. If I do end up getting the 09 RA I would want to run a 17x8 wheel with 235/45/17 tires as there are many good tire choices in this size in addition to being within 1% of the factory speedo.
Old May 31, 2008, 08:49 AM
  #73
Anarchy08's Avatar
Don't know if this will help you but it helped me understand wheel sizes a little better.
http://www.bigcustomwheels.com/rt_specs.jsp
Old Jun 2, 2008, 06:53 PM
  #74
aftermarket's Avatar
Ok, so if it's a 7" wheel instead of an 8", as long as it's 38mm in offset, with that tire combo, that would be fine with ZERO issues (on a stock height Lancer)?
I have 16's on my SE, and would like a little bigger, but not crazy about 18's.
Old Jun 3, 2008, 10:14 AM
  #75
BlackGTS's Avatar
i was wondering if these rims would fit the gts? http://toronto.en.craigslist.ca/tor/pts/652732928.html Would the bolt pattern work with the gts and could i use the stock tires for it? Thanks for any help
Quick Reply: Official Wheel/Tire Info Thread
