Brake problem pt II
Brake problem pt II
My car's wheels squeak at low speeds. The squeak stops WHEN i brake..
the squeak has been getting on my nerves for a long time now, I took it back to the spot where I had my brakes changed, they said I needed new rotors; which is total bs, I had them resurfaced a few months prior to hearing the noise..
Need help!!!!!!
Need help!!!!!!
what kind of pads do you have and are they properly shimmed?
i've got porterfield full race pads on my lancer and they are noisy as hell... even after shimming and lubricating EVERYWHERE... they don't shut up. they sure stop good though. oh well!
But his problem is noise when he is NOT braking.
How much meat is left on your pads?
You said you got your rotors worked on a few months ago, you know that a few months can do wonders on your rotors; right?
Squeaking from the brake assy when you are not braking is usually caused by worned pads. The warning pin rubs against the rotor when you drive and shuts up when you start braking. That's usually a sign your pads are about to go, or it might also be a sign of something improperly aligned in your brake assembly.
The rotor could be warped, the pads could be sitting at a slight angle, there could be a rock or whatever stuck in the assy. I say you should just take it appart and investigate yourself.
when I had it checked out at the time, there was plenty of meat left on the pads (80%), due to the fact that when the rotors were worked on a few months prior, the pads were replaced as well...
it is more than a few months now, the resurfacing (and pad replacement) was back in january, but I don't track or drive down mountains or stop too abruptly, just typical street and freeway driving; but the squeak has been going on since like.. april
and thanks for the suggestions guys!!
CrackerJackToy
Jan 28, 2008 07:34 PM
