Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
The Sound Of Blown Shocks??
Old Jan 22, 2008, 10:56 PM
GuamLancer's Avatar
Just like the title says. What do blown shocks sound like?
While driving I hear a "clicking" sound. Like metal to metal, or some hard material on itself. It doesn't happen all the time. It seems pretty random. Drive fast, slow, straight, or into a turn it doesn't seem to matter. It just clicks once in awhile. Also, I tried taking the wheel off on the front driver side wheel (where I hear the noise), and while raising or lowering the car, I hear the same sound.
A little help is appreciated...
Old Jan 23, 2008, 01:59 AM
iFeLLdOwN's Avatar
Are you bouncing up and down more than normally?
Old Jan 23, 2008, 03:28 AM
GuamLancer's Avatar
No. My D2 coilover suspension is pretty stiff. I think I even preloaded the springs when trying to raise the ride height. When I first had the coilover installed, I tried to test the bounce of each corner. I honestly think when pushing it down, it can only be pushed an inch. I have a better chance of breaking off the bumper, than getting any real play out of it. And no, that hasn't changed since noticing the clicking noise...
I tried looking in the wheel well again. And yeah that noise is obvious when raising or lowering the car to take off the tire.
Old Jan 23, 2008, 05:12 AM
atilla's Avatar
when i had a blown strut the puddle of hydraulic oil on the pavement under my car gave it away before the noise did.
Old Jan 23, 2008, 12:37 PM
SLVROZ_03's Avatar
Clicking is more likely to be an axle...a blown strut will leak and you should be able to see a build-up of fluid and crap around the leakage area.
Old Jan 23, 2008, 04:44 PM
GuamLancer's Avatar
I agree. But if it were an axle, wouldn't the clicking be a constant noise? Like I said before, the clicking while driving seemed pretty random. But when I jack up the front driver side wheel, it'll make the same clicking sound about two or three times when trying to raise or lower the car.
Just to be safe, that was the reason why I looked in the tire well. To see if maybe it was a torn CV boot or something. But no everything looks ok, except for some white residue on the springs. Could that be something?
And no I haven't noticed any leakage, because my car is always parked on the grass.
Old Jan 23, 2008, 05:12 PM
SLVROZ_03's Avatar
A bad cv doesn't have to make noise constantly; I just replaced two totally exploded boots/axles on my '95 Civic (new used purchase) and one only made noise at low speed cornering/turning...mainly parking lots or backing out.
Yes, the first thing to look at is grease seepage around the boot or dry up grease flung up into the wheel well or neighboring parts. Second, examine the boot for rips or tears. Also check to see that the boot doesn't slide around on the axle...meaning, make sure the metal clips hold the boot tightly against the axle.
Good luck man!
Old Jan 23, 2008, 08:30 PM
GuamLancer's Avatar
Thanks for the diagnosis, slvr. But I already checked out the boot, and it still looks next to new. But check this out.
A mechanic friend of mine at a local shop sprayed lube on the upper mounts, and the sound has quieted down a great deal and no where near as frequent as before. Its still there, but WAY more tolerable...
What do you guys think of that?
Old Jan 23, 2008, 08:57 PM
02-Lancer-Es's Avatar
if i were you i would just take both front wheels off and tighten every bolt under there , i remember i left a bolt loose and it would make a "clunk" sound and thats all it was , a loose bolt(not completely loose but not all the way tightened)
Old Jan 24, 2008, 10:59 AM
SLVROZ_03's Avatar
When you say upper mounts, did you mean the upper strut mounts or the engine/tranny mounts?
Old Jan 24, 2008, 11:15 AM
sXericerider's Avatar
i have the same issue on my passenger side it clicks once in a while when i'm driving slow going over cracks or humps. but at the times i wanna try to make the noise it doesn't. it clicks randomly as well i guess.
Old Jan 24, 2008, 08:32 PM
GuamLancer's Avatar
The upper strut mounts. My D2 came with a camber plate. He just sprayed lube in there and it quieted down quite a bit. He says coilovers sometimes need lube on the outsides where there is movement. Or something to that effect. Seems to have helped...
Old Jan 24, 2008, 11:29 PM
sykou's Avatar
Here's a fix!!
Okay I have exactly the same problem with my coilovers. the noise is not caused by the camber plates although cleaning/greasing them does help out a bit. the noise is caused by spring binding. If you lift your car up with the wheels off the Well to explain spring binding, it all has to do with the spring not freely spinning when the strut is rotated. When you turn your wheel back and forth the strut assembly also turns. What does most of the rotation is the lower half of the strut, but the top half also does some rotation of its own.
The stock strut assembly is made with a sort of bearing type piece that is placed in between the strut top and the upper mount. This bearing allows the strut to rotate more freely. As for aftermarket coilovers, there is no such bearing. If your coilover has a pillowball mount then it is the job of the mount to allow movement and this is somewhat limited.
Because there is so much friction between the pillowballmount the strut must rotate elsewhere. So the next logical place would be the spring mounts. The spring mounts are locked into place on the strut itself so the area where the spring contacts the spring perches is where the rotation occurs. The sound that is created is a sort of low popping with a little echo/resonance. The spring "slips" within the perches and this causes the noise. Now for the fix...Go grab some WD-40 and without the straw just go and apray the hell out of the springs and spring perches. If you can, loosen up the pillowball mounts a very small amount as to allow it to move more freely. Clean the pillowball mounts with pb blaster and regrease them with a heavy grease. Don't use the light stuff as it will just drip off. Hope it works for the rest of you. Good luck!
Old Jan 30, 2008, 02:49 AM
GuamLancer's Avatar
Thanks. I'll be sure to do that.
Old Jan 30, 2008, 01:42 PM
SLVROZ_03's Avatar
Since I've upgraded to Evo fronts with the ball bearing bear in the top mount, turning has been soooooo smooth. I could tell a difference right off the bat...even with PS! And yes, an un-set spring will make sounds/noises; a friend and I did new struts and springs on his 240. Put them on and at ever turn you could hear something. Turned out the spring wasn't seated against the factory point at the bottom. Compressed the spring again and twisted it...bingo! Problem solved.
aptok14
Jan 27, 2017 06:28 PM
donmeca2020
Jun 9, 2009 09:54 AM
jluckyp
Mar 11, 2008 07:43 PM
mcwop23
Jan 10, 2007 07:30 AM
EvoG8r
Jan 2, 2005 09:17 PM
Quick Reply: The Sound Of Blown Shocks??
