Sway Bars for 03 Lancer ES? Fix bad handling
I'm trying to tighten my suspension and better my handling for general purposes, an I thought sway bars would be a good start.
Has anybody else put sway bars on there 03 ES? If so a how - to would be great because im not too sure where to begin. I am trying to learn everything I can before making any purchases, my main goal is to tighten my suspension and handling. My car sways all over the highway and doesn't feel safe at times. If anybody has any helpful information that would be great! Thanks!
that was very helpful
I had heard about sways & struts for years but never really knew anything about them. So I did some research. Gonna go ahead and put front & rear struts first, than sways. Then figure out what to do next if I'm still not satisfied! I have ordered a few of the parts but due to the holidays they may take a week or two before they are delivered. Once they are in I'll keep this post updated though!
get your alignment checked. and make sure the front sway bar (front stabilizer) endlinks are not broken, and that the bushings are intact.
after that. installing the sway bar is simple, though being an ES, could require some special tools, like a tap and die set.
for a swaybar, anything that fits the CS6A (ES,LS,OZ 2002-2006) or CS7A (Ralliart 2004-2006) chassis will all be the same...when I installed my whiteline bar in my ralliart, I put my stock ralliart swaybar on the ES, and it handled much better...
for installation, you'll need some oem parts (bolts mounts and brackets)...if you get an aftermarket bar, it should include bushings. The mounting points are already in the chassis (bolt holes for bar mounts), for mine, they were very corroded and had to be tapped. If they're really bad, they may need to be re-drilled and tapped at a larger diameter. I have some decent pictures of my bar installed...it's pretty easy to see where everything goes. no, I don't think that's an approved jacking point
That helps tremendously, especially the images. They will definitely come in handy when it comes time to install the sway bar. Im going to get my alignment checked out after the holidays shortly before I purchase the sway bar.
I already went ahead and bought some strut bars because they weren't too expensive, im not expecting them to do much but they could only help. Again I appreciate all of that information, its definitely going to help me tighten up the suspension on my ES!
Hey I had a quick question. Do you know if a sway bar for a CS5W Cedia Ralliart Wagon would also fit on an 03 Lancer ES? I found a nice sway bar that says it fits an 03 Cedia Wagon but it doesn't say if it fits an 03 ES. I believe it does but I'm not positive so I thought I would ask. Thanks
-Gary
-Gary
I was checking out that whiteline sway bar you mentioned but whiteline discontinued it. Though im sure I can still find a front and rear one somewhere online.
But the one i was looking at that fit the Cedia Wagon was for the front and I believe they made one for the rear as well. They are Cusco brand. A bit too expensive if you ask me, I think ill go with the whiteline, they are cheaper and will do the job.
I'll probably just buy the rear and leave the front alone. I was not aware the ES didn't have a rear...I can only imagine the difference. The only front bar for an ES that i was able to find was a Cusco brand for about $300. I don't think the car is worth putting too much into it though especially if it already has a decent bar in it. Ill post when I put it on & the difference it makes
