Lancer Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack From suspension settings to new wheels and tires or brake upgrades... it's all covered here. Sponsored by: The Tire Rack
2002 Lancer LS shock absorber; help
Old Jan 21, 2017, 10:21 AM
cbrooks671's Avatar
So I replaced the shock absorbers(the rear) on my 2002 Lancer LS.
Before I replaced the shock, it never had any noise.
Now that the new ones are in, it has a horrible creaking sound.
(Shocks on the rear were replaced due to an observed leak around it)
The bushings on the upper mount looked okay. Wasn't cracked or brittle.
I followed the service manual torque specs.
Noise occurs when you even just touch the car, it creaks. or even just leaning on it. Especially when driving on the road just little bumps will make it creak so loud.
I need help please. Its a problem that I can't seem to solve.
Old Jan 21, 2017, 09:49 PM
CrAnSwIcK's Avatar
is the squeak for sure in the rear end? lubricate every bushing...don't use petroleum based lubricant...
Old Jan 22, 2017, 03:37 AM
cbrooks671's Avatar
I'm sure that it is coming from the rear. I sprayed every bushing that I saw with silicone spray and it still does it.
I have read about a TSB about the rear lower control arm going bad. I'm going to inspect mine to see if the noise is coming from there.
redstarbelgrade
May 3, 2014 06:35 PM
L888Apex
Sep 27, 2012 04:05 PM
Chamama
Nov 6, 2006 01:56 AM
solarxclipse
Aug 3, 2004 11:07 PM
evo2?
Dec 4, 2003 06:00 PM
Quick Reply: 2002 Lancer LS shock absorber; help
