Need a new clutch for 2003 lancer oz, recommendations?
Hi, I have 2003 lancer oz manual with 95k miles.
The car is drivable but the clutch started slipping at high revs. If driven easily it works fine but I thought it might be a good idea to change the clutch.
I don't have any mods but I might put just the cold air intake. Anyway I am looking for quicker engagement then stock but want to keep similar pedal feel to stock or just a bit harder.
These clutch kits I have found so please make me a recommendation or let me know if there are some other better kits.
ACT MB8-HDSS for $280
ACT MB8-XTSS for $350
These act clutch kits don't come with any slave cylinder nor bearings so where can I buy slave cylinder/bearings. Do they need to be some upgraded parts or even stock would be fine?
Exedy MBK1004 for $255, this one comes with all the parts needed. I am not sure but is this stock oem clutch or is it a bit better then stock?
Thanks a bunch
Thanks a bunch
Thanks a bunch
Thanks a bunch
i have the xtss and its enough for my turbo setup, if ur planning on doing that then get it, i got the slave cyclinder from rrm i had to order it through the phone though and i forgot how much it was but less than 140
If you dont hear your slave ticking then dont bother wit it, but you do have 95k on it so you should do it since u are gonna put a aftermarket performance clutch. I got my Slave for a $100 from the dealer.
^ +1....unless you plan on going turbo I wouldn't bother with anything more than ACT stage 1 while your in there replacing the clutch look into installing a light weight flywheel def worth the $
Where did you FX300 with bearing for 405?
Does anybody know if clutchmasters FX100 part number 05-051-HD00 will fit 2003 lancer oz.
On ebay it mentiones that it's for 2004-2006 lancer, but on speedcorps.com it shows that it would fit from 2002-2006.
Thanks
Thanks
The disc and pressure plate would fit, but the throwout bearing will not. All clutches for 2002-2006 Lancer 4G94 engines are the same. There is a different throwout bearing for 2002-2003 & 2004-2006. So that kit would be for a 2004-2006. You could use it. You would just need to also buy a new throwout bearing from somewhere to install with it.
