02 lancer OZ Slave cylinder bleeding
I Just got doing the clutch install in my moms car last night, and i was just wondering if there is a special way to bleed the Slave cylinder? Well if someone could help me out with this will be really helpful. The clutch pedal feels kinda weird, just not sure if it is right. So thanks for the help if you can help me out.
MIKE
MIKE
Here is the basic rundown to bleeding a clutch. First off do not bleed a clutch like you do a brake. Have someone in the car while you are underneath with the slave. Open the bleeder valve, have them push the pedal all the way to the floor and hold it there. Close the bleeder valve, then have them let off the pedal all the way. open the valve and have them push the pedal to the floor again and hold, close the valve and let of the pedal. Continue this until you get a string of 2 or 3 solid streams of fluid coming out of the valve to confirm all the air is out. DO NOT lift the pedal at all until the valve is closed or you will just be sucking air back into the sytem.
beautifulpunk
Lancer Tranny/Drivetrain Tech
Oct 20, 2011 07:25 PM
