allow your es/de go into sport mode (same as GTS)
#31
tiptronic shifter swap....successfully done
Works perfect for me...took me an hour and half to take off the old one and install the tiptronic shifter. Now my SE lancer 2008 is now 6speed.
#32
Paddle shifters are plug and play too. I'm not too sure about the cruise but if you get the buttons they should be plug and play on the steering wheel since the harness is already there and it should be programmed in already.
#34
#36
I have a 2015 es and I bought the paddles but I can’t find anywhere to plug them in any help?
#37
you have to have the wiring harness.. I read that it’s tape so you have to look right there but I took mine to a mechanic I know and he put them on for me and they work really good..
#38
I checked everything and couldn’t find a harness anywhere to connect to the paddles harness. I might just have to take it to a mechanic and have them figure a way to wire it up then.
#41
2015 Lancer ES/2016 GTS shifter
Yo I'm seeing all these messages about how it works I tried that with the 15 with a 2016 shifter and everything works apart from the actual positive and negative shifter nothing shows up on my screen when I click to drive over I don't feel anything when I click the positive and negative up and down what am I doing wrong everybody seems to have it figured out it's really easy to install no brainer why is not working somebody you help me get an explanation so I can conclude this BS modification
#42
I have a 2011 lancer ES, and I am willing to do this mod because I know that I am not selling it for a while. Does anyone know which year does the assembly shifter from the gts has to be. I saw that the 2009 gts assembly did not work on the 2011 es. Does it have to be an older year??
#44
most of the 08 de/es's don't have cooler and some 09's don't either. by 2010 every cvt had a tranny cooler, except for a few random instances. If you don't have a tranny cooler you can add one from a gts or from es/de that had one standard. but you'll need more than just the cooler and the lines. you also need to install the inner tranny cooler that has the extra inlet and outlet lines to accommodate the external cooler.
#45
Do y’all know if that works for Mitsubishis lancer DE 2009
I was wondering that because I try to install some shifter paddles but my car didn’t have the wire to connect the paddles and idk if is gonna be the same with that thing
PHANTOMx47x
Oct 24, 2017 06:02 AM
Blacksheepdj
94
Dec 3, 2016 02:13 PM
