help with clutch that wont bleed
wondering if anyone could tell me what might be causing my clutch to not pump up. There is a steady stream of fluid coming out of the bleeder valve but still no pedal. I was wondering if it may be my slave cylinder. any thoughts would be greatful.
thanks
thanks
sounds like the slave cylinder to me. there should be rubber grommets in there to hold the pressure and if their bad then no pressure. happened to my buddies truck and his clutch was bad too
Ralli_Red
Apr 7, 2020 12:35 PM
Gary@MellonRacing
Sep 5, 2008 01:34 PM
