input/output shaft bearing replacement and TOB
I'm in the middle of tearing down the trans out of my 05 lancer right now. i was having a bad sound that i concluded to be a bad shaft bearing. so far i'm having a hell of a time separating the casing.
I was also curious if a 02-03 lancer MT throwout bearing would work in my 05 trans? Since i do have the 16g turbo my slave is still somewhat in the way even tho i already have a solution.
ok well i finally got the case apart. had to remove the black plug on the back and loosen the clip to let the output shaft come loose.
looks like i have some bad wear on the inside of the case :/ im guessing whatever caused the noise i was getting caused this as well.
Do you guys know the part number for this seal and where to find it I can't find one I've been given two different seals from Oriellys but they weren't the right ones. Thanks in advance!
bh117
23
May 13, 2017 07:07 PM
FS[MidWest]: input and output trans bearings
tsidrift1
Dec 19, 2016 01:28 PM
WTB[West]: Evo 9 input shaft
Paulevo9
Mar 23, 2016 08:01 AM
jeg5263
Lancer Tranny/Drivetrain Tech
Feb 16, 2016 09:24 PM
mci2727
24
Feb 12, 2016 11:11 AM
