Question: 02 oz rally manual transmission in 04 lancer es
I was wondering if you can take a manual transmission out of a 02 oz rally and put it into a 04 lancer es? Because doesn't it have the same engine?
So the pedal kit should just bolt up to the body or do I have to make any modifications? Then mount to master cylinder from the engine side of the firewall to the clutch pedal bolts then run a flex line from the master cylinder to the external slave and have the slave connected to the pivot arm?
yeah, pretty sure you need an ECU/control harness, some people have done it, but it's a big job, there's wiring behind the dash that needs to replaced/removed, you'll also need the shifter/base, shift cables etc. so you need to pull the dash out. you need the whole pedal assembly with the interlock switch...not sure if the auto has the mounting points or not...you'll need the clutch master, again mounting points may or may not be there. rear tranny mount I'm pretty sure is different. you probably need a brake reservoir if the auto doesn't have the tap off for the master, you'll need the slave, flywheel, clutch, transmission...you'll probably need a gauge cluster for a manual as well, but I'm not entirely sure....there are threads on the subject but it's not as simple as you might think...
The gauge cluster is interchangable so that you can keep. Fortunately the brake reservoir can be used with the 5spd master, too.
I was gonna buy the whole oz rally car that has been wrecked found it for cheap. I was just wondering if that year you could swap cause I know one of the years you couldn't and yeah I know it will be a big job I just want it to be a learning experience and I'm going to uti been learning a lot so I'm not as dumb as you'd think but I'm not saying I'm a genius lol I just have a dream for working on cars sport bikes etc anything mechanical and only 19 years old
seankhan
49
Nov 26, 2019 01:43 AM
wesleylawson6
Lancer Engine Tech
Mar 30, 2016 08:02 PM
AWDTFTW
Jan 25, 2015 11:51 AM
ShadowzOz
Lancer Tranny/Drivetrain Tech
May 8, 2012 10:24 PM
