Need help removing strut top nut!!
Old Aug 2, 2007, 03:47 PM
alveezy's Avatar
I need help with taking off the nut on my front shocks! The nut in the center won't come off because the rod spins with it. Am I doing something wrong!? Do I need a specific tool to take it off?? HELP ME!
Old Aug 2, 2007, 04:00 PM
SLVROZ_03's Avatar
Impact gun...might I ask what you're doing?
Old Aug 2, 2007, 04:08 PM
Frankracer88's Avatar
ya u need an impact gun. I live up in Carlsbad if u need any help with this. Im guessing your putting in new springs or something. Hit me up on here if u need some help.
Old Aug 3, 2007, 06:51 AM
Blacksheepdj's Avatar
Impact gun is the only way. You can usually rent one from the local autoparts store.
Old Aug 3, 2007, 07:15 AM
jenx1976's Avatar
mount the strut back in place in the wheel well then lossen the bolt., i learned this the hard way also....
Old Aug 3, 2007, 07:20 AM
azturbolancer's Avatar
You can do it with a breaker bar you just have to reassemble the strut....+1 for learning this the hard way as well LOL
Old Aug 3, 2007, 08:56 AM
Pretty sure the piston still turns. Might be a difference between Evo and Lancer struts?
Old Aug 3, 2007, 09:59 AM
SLVROZ_03's Avatar
If you happen to have one of those rubber strap Craftmen wrenches, you could try wrapping that around the strut piston and torque on the top nut. But impact gun will take less than a sec to get that off. Hell, the first time I actually took my two front struts w/ springs into the Sears garage. They zipped it off in a second...helps that you know someone there though.
hatesposers
Jul 1, 2013 11:19 PM
BerserkerX
10
Nov 29, 2007 03:32 PM
evoXIII
Jun 3, 2007 06:56 AM
snakedelong
May 17, 2007 08:02 PM
vietxscapeD
Oct 24, 2002 10:56 PM
Quick Reply: Need help removing strut top nut!!
